    Connecting to web control
    Duet Web Control
    1.0k
    • Yarundefined
      Yar
      Yes, stock screen and encoder. I figured out the display and encoder, they function now.
      Yes, Reprap 2.05.1. DWC 2.0.4
      That's is the instruction set I've been following since the start.
      Going through the tests both heaters are showing fault. I double checked the wiring based on the instructions. Suggestions?
        What exactly does the fault error message say?
        M305 P0 T9880 B4185 R4700 ; set thermistor + ADC parameters for heater 0
        M143 H0 S80 ; set temperature limit for heater 0 to 80C
        M305 P1 T9880 B4185 R4700 ; set thermistor + ADC parameters for heater 1
        I think your T values may be missing a digit.
        Should be 98801
        The screenshots in that guide cut off the last character of that value but it's basically close to 100000.
        • Yarundefined
          Yar
          Based on your suggestion I changed the value by adding a "1", so 98801. That fixed both the hot end and the bed! Thanks for that! My bad for looking at the image, not the text!
          My next issue is setting up for a EZABL. I've looked at the install text from TX3D. At this point I don't want to mess up what has been done, but the printer clearly isn't recognizing the sensor isn't funtioning properly without its code. The instructions say to install config.h (appropriately adjusted) but I don't find a config.h in the sys file. Should I simply add it?
          Really appreciate your patience and assistance with all this!!
            Phaedrux Moderator @Yar
            @Yar said in Connecting to web control:
            config.h
            Probably means config.g which is the main configuration file for RepRapFirmware.
            • ziggymanpopoundefined
              ziggymanpopo
              Check M588 the type of sensor "might" be wrong for abl
              Once thats set and it functions...calibrate height. Procedures There are complete instructoind on how to setneverything in The duet documentation portion of this site. Hope this helps. To get to that part hit the three bars at top left for site pulldown menus look for the z-probe section there is tables with all the sensor setting for any z probe sensor
              (Just in case) 🙂 hope this help
              • Yarundefined
                Yar
                Found a post on your site
                https://forum.duet3d.com/topic/8963/ezabl-z-probe-wiring-and-configuration/8
                TH3D's suggested code is M558 P5 C"!zprobe.in" H3 F900 T1200. When I change the probe type as in the post to l1 for M558 the sensor seems to work fine. However, when I turn off the machine then turn it back on the sensor doesn't work, unless I put the M558 in again.
                Thoughts?
                  @Yar P5 is from before P9 existed specifically for the BLtouch.
                  • Yarundefined
                    Yar
                    Interesting. Like I said, as Duet's post showed, the l1 makes the sensor function. But when I cycle the power I have to reset the M558. Shouldn't that stay in memory?
                      @Yar No there is no "in memory" for the Duet. Everything is configured at boot up with config.g and can be configured manually by sending the command while it's running, but sending the command while it's running won't persist after a power cycle.
                      • Yarundefined
                        Yar
                        Ah, I'm slow, but catching up . . . slowly. So if I make the change in YAT that would put it in memory?
                        Since I have you, the x and y home to the front left corner. The z probe is homing slightly right of that. Shouldn't it be in the center?
                          It will remain until the next reboot
                          Homing is controlled by the homeall, homex, homey, homez macros. It will do whatever the commands in those files tell it to do.
                          https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files
