    Z homing in wrong direction
    CNC
    • Yveskeundefined
      Yveske
      After changing to the beta version of the CNC UI, the Z axis always goes down towards the spillboard during homing instead of up.
      Changed M574 Z2 to Z1 and back with no avail.
      M569 P0.0 S0                                ; physical drive 0.0 direction (0 = backwards, 1 = forwards (default 1))
      M569 P0.1 S0                                ; physical drive 0.1 direction (0 = backwards, 1 = forwards (default 1))
      M569 P0.2 S0                                ; physical drive 0.2 direction (0 = backwards, 1 = forwards (default 1))
      M569 P0.3 S1                                ; physical drive 0.3 direction (0 = backwards, 1 = forwards (default 1))
      M574 X1 S1 P"!io0.in"                       ; configure active-high endstop for low  end on X via pin io0.in
      M574 Y1 S1 P"!io1.in+!io2.in"               ; configure active-high endstop for low  end on Y via pin io1.in
      M574 Z2 S1 P"!io3.in"                       ; configure active-high endstop for high end on Z via pin io3.in
      • fcwiltundefined
        fcwilt
        The direction of homing is controlled by the commands in your homeZ.g file.
        Please post that.
        Yveskeundefined 1 Reply Last reply Reply Quote 0
        • Yveskeundefined
          Yveske @fcwilt
          @fcwilt
          Thanks for pointing me in the right direction. Problem solved !!!
          I do wonder how it ever could have worked before...
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt @Yveske
            @Yveske
            Glad to hear you got it working.
              Phaedrux Moderator @Yveske
              @Yveske said in Z homing in wrong direction:
              A combination of telling it to move in the wrong direction but also having the motor rotate in the wrong direction.
