    Cannot access gpin in code
    Gcode meta commands
    • fcwiltundefined
      fcwilt
      Testing firmware 3.3 beta 2 on a 6HC.
      I created a gpin:
      As you can see It appears in the DWC Object Model browser and correctly displays the input state.
      However trying to execute echo sensors.gpin[0].value from the DWC console yields an error message Error: meta command: unknown value 'gpin^.value'
      Any ideas why?
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • hmortensenundefined
        hmortensen
        Have you tried copying the value from the object browser?
        In the screenshot it seems to be capital letter I in gpIn and your echo command is all lower case.
        fcwiltundefined 1 Reply Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @hmortensen
          @hmortensen said in Cannot access gpin in code:
          Good catch - you must have sharp eyes.
          For some reason things are case-sensitive and the lower case letter was the problem.
          Thanks much.
          • OwenDundefined
            OwenD @fcwilt
            This post is deleted!
