    '/RepRapFirmware-RADDS.elf': No such file
    Firmware installation
    • Bobbyofna
      Bobbyofna last edited by
      Hello I am trying to compile RRF because I need to swap the 3rd heater pin and the heated bed pin as my heated bed mosfet on radds died. I made the change in the pins.h file but I am having trouble getting the final firmware file. Everything compiles but the last command is…
      [[language]]
      arm-none-eabi-gcc "-LC:\\Eclipse\\Firmware\\CoreNG\\RADDS" -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m3 "-TC:\\Eclipse\\Firmware\\CoreNG\\variants\\RADDS\\linker_scripts\\gcc\\flash.ld" -Wl,-Map,/RepRapFirmware-RADDS.map -o RepRapFirmware-RADDS.elf -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\\Eclipse\\Firmware\\CoreNG\\RADDS\\cores\\arduino\\syscalls.o" "src\\Fan.o" "src\\FilamentSensors\\Duet3DFilamentSensor.o" "src\\FilamentSensors\\FilamentSensor.o" "src\\FilamentSensors\\SimpleFilamentSensor.o" "src\\GCodes\\GCodeBuffer.o" "src\\GCodes\\GCodeInput.o" "src\\GCodes\\GCodeMachineState.o" "src\\GCodes\\GCodeQueue.o" "src\\GCodes\\GCodes.o" "src\\GCodes\\GCodes2.o" "src\\GCodes\\RestorePoint.o" "src\\Heating\\FOPDT.o" "src\\Heating\\Heat.o" "src\\Heating\\Pid.o" "src\\Heating\\Sensors\\CpuTemperatureSensor.o" "src\\Heating\\Sensors\\CurrentLoopTemperatureSensor.o" "src\\Heating\\Sensors\\RtdSensor31865.o" "src\\Heating\\Sensors\\SpiTemperatureSensor.o" "src\\Heating\\Sensors\\TemperatureSensor.o" "src\\Heating\\Sensors\\Thermistor.o" "src\\Heating\\Sensors\\ThermocoupleSensor31855.o" "src\\Heating\\Sensors\\ThermocoupleSensor31856.o" "src\\Heating\\Sensors\\TmcDriverTemperatureSensor.o" "src\\Heating\\TemperatureError.o" "src\\Libraries\\Fatfs\\ccsbcs.o" "src\\Libraries\\Fatfs\\diskio.o" "src\\Libraries\\Fatfs\\fattime_rtc.o" "src\\Libraries\\Fatfs\\ff.o" "src\\Libraries\\General\\StringRef.o" "src\\Libraries\\Math\\Isqrt.o" "src\\Libraries\\sha1\\sha1.o" "src\\Movement\\BedProbing\\Grid.o" "src\\Movement\\BedProbing\\RandomProbePointSet.o" "src\\Movement\\DDA.o" "src\\Movement\\DriveMovement.o" "src\\Movement\\Kinematics\\CartesianKinematics.o" "src\\Movement\\Kinematics\\CoreBaseKinematics.o" "src\\Movement\\Kinematics\\CoreXYKinematics.o" "src\\Movement\\Kinematics\\CoreXYUKinematics.o" "src\\Movement\\Kinematics\\CoreXZKinematics.o" "src\\Movement\\Kinematics\\Kinematics.o" "src\\Movement\\Kinematics\\LinearDeltaKinematics.o" "src\\Movement\\Kinematics\\ScaraKinematics.o" "src\\Movement\\Kinematics\\ZLeadscrewKinematics.o" "src\\Movement\\Move.o" "src\\OutputMemory.o" "src\\Platform.o" "src\\PortControl.o" "src\\PrintMonitor.o" "src\\RADDS\\Network.o" "src\\RepRap.o" "src\\RepRapFirmware.o" "src\\Roland.o" "src\\Scanner.o" "src\\SoftTimer.o" "src\\Storage\\CRC32.o" "src\\Storage\\FileStore.o" "src\\Storage\\MassStorage.o" "src\\Tools\\Filament.o" "src\\Tools\\Tool.o" "src\\ZProbeProgrammer.o" -lCoreNG -Wl,--end-group -lm -gcc
      arm-none-eabi-objcopy -O binary /RepRapFirmware-RADDS.elf /RepRapFirmware-RADDS.bin
      arm-none-eabi-objcopy: '/RepRapFirmware-RADDS.elf': No such file
      I do get a .elf file but im not sure how to get the actual firmware .bin file. I've tried changing the extension to .bin instead of .elf but the file is double the size of the latest 1.19 RRF binary. What do I do? Thanks!
      • Bobbyofna
        Also, even tho it seems to compile, I get these errors…
        [[language]]
        Description	Resource	Path	Location	Type
        Function 'ARRAY_SIZE' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 158	Semantic Error
        Symbol 'NoPin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 70	Semantic Error
        Symbol 'NoPin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 129	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 52	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 54	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 55	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 70	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 79	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 86	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 102	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 105	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 110	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 114	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 118	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 124	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 128	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 129	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 130	Semantic Error
        Type 'Pin' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 151	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 6	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 21	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 29	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 35	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 36	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 40	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 41	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 42	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 44	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 99	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 117	Semantic Error
        Type 'size_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 127	Semantic Error
        Type 'uint32_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 161	Semantic Error
        Type 'uint32_t' could not be resolved	Pins_RADDS.h	/RepRapFirmware/src/RADDS	line 162	Semantic Error
          I updated the .cproject file recently to change the name of the generated file to RepRapFirmware-RADDS for the RADDS build instead of just RepRapFirmware. It looks like you haven't picked up that change.
          Eclipse often gives a heap of semantic errors, usually when you have just changed the active build configuration. They usually go away when you compile or re-index.
