    DSF-API pydsfapi and CPU utilization on RPi during print
    Using Duet Controllers
    • resamundefined
      resam
      I'm running all the latest stable releases:
      RRF 3.2.2, DSF 3.2.2, DSF-APIs/pydsfapi 3.1.3
      on a Raspberry Pi 3B+.
      I'm running a simply Python app to intercept M7000 and take a webcam photo during a layer change - so only once every few minutes:
      intercept_connection = pydsfapi.InterceptConnection(InterceptionMode.PRE)
      intercept_connection.connect()
      while True:
          cde = intercept_connection.receive_code()
          if cde.type == code.CodeType.MCode and cde.majorNumber == 7000:
              success = intercept_connection.flush(cde.channel)
              if not success:
                  log_print("Flush failed")
                  intercept_connection.cancel_code()
                  continue
              take_camera_snapshot()
              intercept_connection.resolve_code()
          else:
              intercept_connection.ignore_code()
      While printing, I observe that this python process is essentially pegging a whole CPU core: almost or even slightly more than 100% in htop.
      The /opt/dsf/bin/DuetControlServer process is hovering around 10-15% of CPU (when looking at htop)
      My total system memory with an print job:
      $ free -h
                    total        used        free      shared  buff/cache   available
      Mem:          924Mi       172Mi       548Mi       6.0Mi       203Mi       693Mi
      Swap:            0B          0B          0B
      Is this a bottleneck that could affect print performance?
      How does DSF/DCS behave if one of the IPC clients cannot keep up, @chrishamm?
      Am I using it wrong, @wilriker?
      Would the Go-based API be more performant and should be preferred over Python?
      resamundefined 1 Reply Last reply Reply Quote 0
      • resamundefined
        resam @resam
        Of course as luck will have it, I cannot reproduce it anymore.
        So take my report from above as tainted - might have been a race condition or something else. ¯_(ツ)_/¯
        wilrikerundefined 1 Reply Last reply Reply Quote 2
        • wilrikerundefined
          wilriker @resam
          @resam Whatever it was, you can also avoid high load when using pydsfapi 3.2.0 or later by making use of the filters parameter when instantiating Intercept_connection. It takes a list of strings specifying those codes you are interested in. DSF will then only forward these codes to your client.
          I have modified your new code example to show how to use it.
          Manuel
          My Tool Collection
