    rehome puzzle
    Using Duet Controllers
    rehome.g homing pause
    1
    • printernoodleundefined
      printernoodle
      Oh hello and thanks for looking!
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.25
      Edit: was using 3.2 updated to 3.2.2 same outcome.
      Setting up stall detection here...or trying to.
      rehome.g is successfully called after a stall is detected using "M915 X Y Z S3 F0 R3".
      In my case, regardless of what I've tried, the machine produces rather nasty belt skipping on one or more of the 3 towers (cant tell....don't want to pop a belt).
      I also get the homing failed warning message and then the print tries to resume.
      Read on...
      The "M915 X Y Z S3 F0 R2" option (to simply pause) seems to work and I'm able to manually home at that point with "G28". I am also able to manually resume after that homing call or of course just resume after pause is called by the M915 with R2 option....so that all works.
      Code you say?
      printernoodleundefined 1 Reply Last reply Reply Quote 0
        printernoodle @printernoodle
        Config.g
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 10 2021 22:07:00 GMT-0400 (Eastern Daylight Time)
        G90                                                  ; send absolute coordinates...
        M83                                                  ; ...but relative extruder moves
        M550 P"Red Queen"                                    ; set printer name
        M665 L298.700:298.700:298.700 R149.058 H355.596 B130.0 X0.428 Y0.399 Z0.000                  ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0.453 Y0.269 Z-0.722 A0.00 B0.00                                        ; put your endstop adjustments here, or let auto calibration find them
        M551 P"*************"
        M552 S1                                              ; enable network
        M586 P0 S1                                           ; enable HTTP
        M586 P1 S0                                           ; disable FTP
        M586 P2 S0                                           ; disable Telnet
        M569 P0 S1                                           ; physical drive 0 goes forwards
        M569 P1 S1                                           ; physical drive 1 goes forwards
        M569 P2 S1                                           ; physical drive 2 goes forwards
        M569 P3 S0                                           ; physical drive 3 goes backwards
        M584 X0 Y1 Z2 E3                                     ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                              ; configure microstepping with interpolation
        M92 X200.00 Y200.00 Z200.00 E620.00                  ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E300.00             ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E3600.00          ; set maximum speeds (mm/min)
        M201 X4000.00 Y4000.00 Z4000.00 E600.00             ; set accelerations (mm/s^2)
        M906 X2000 Y2000 Z2000 E500 I30                      ; set motor currents (mA) and motor idle factor in per cent
        M84 S1200                                              ; Set idle timeout
        M571 x1 y1                                            ; set axis correction factor
        M208 Z0 S1                                           ; set minimum Z
        M574 X2 S3                                           ; configure sensorless endstop for high end on X
        M574 Y2 S3                                           ; configure sensorless endstop for high end on Y
        M574 Z2 S3                                           ; configure sensorless endstop for high end on Z
        M574 E2 S1 P"e0stop"                                 ; configure active-high endstop for high end on E via pin estop
        M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F800 T10000  ; set Z probe type to effector and the dive height + speeds
        G31 P500 X0 Y0 Z-0.255                                  ; set Z probe trigger value, offset and trigger height
        M557 R130 S20                                        ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bedheat" T0                                ; create bed heater output on bedheat and map it to sensor 0
        M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                              ; map heated bed to heater 0
        M143 H0 S120                                         ; set temperature limit for heater 0 to 120C
        M307 H0 R0.350 C261.300:261.300 D1.57 S1.00 V23.9 B0     ; bed tuning data
        M308 S1 P"e0temp" Y"thermistor" T100000 B4138        ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                                 ; create nozzle heater output on e0heat and map it to sensor 1
        M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
        M307 H1 R4.061 C128.0 D9.76 S1.00 V24.1                  ; hot end tuning data  M307 H1 R4.061 C128.0 D9.56 S1.00 V24.1
        M143 H1 S320                                         ; set temperature limit for heater 1 to 320C
        M950 F0 C"fan0" Q60                                  ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1 L0.25                                      ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q60                                  ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                                    ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan2" Q60                                  ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S255 H-1 L0.25                                   ; set fan 2 value. Thermostatic control is turned off
        M563 P0 S"Squirt squirt" D0 H1 F0                    ; define tool 0
        G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
        G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
        M572 D0 S0.02                                            ; set K-factor
        M575 P1 S1 B57600                                    ; enable support for PanelDue
        M501                                                 ; load saved parameters from non-volatile memory
        M591 D0 P7 C"e0stop" L7 R50:200 E15 S1                   ; configure BTT smart filament sensor
        M911 S23.5 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        T0                                                   ; select first tool
        bed.g
        ; bed.g
        ; called to perform automatic delta calibration via G32
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 10 2021 22:06:59 GMT-0400 (Eastern Daylight Time)
        ; Probe the bed at 12 peripheral and 3 halfway points, and perform 6-factor auto compensation
        ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
        G30 P0 X0 Y124.9 H0 Z-99999
        G30 P1 X62.45 Y108.17 H0 Z-99999
        G30 P2 X108.17 Y62.45 H0 Z-99999
        G30 P3 X124.9 Y0 H0 Z-99999
        G30 P4 X108.17 Y-62.45 H0 Z-99999
        G30 P5 X62.45 Y-108.17 H0 Z-99999
        G30 P6 X0 Y-124.9 H0 Z-99999
        G30 P7 X-62.45 Y-108.17 H0 Z-99999
        G30 P8 X-108.17 Y-62.45 H0 Z-99999
        G30 P9 X-124.9 Y0 H0 Z-99999
        G30 P10 X-108.17 Y62.45 H0 Z-99999
        G30 P11 X-62.45 Y108.17 H0 Z-99999
        G30 P12 X0 Y62.4 H0 Z-99999
        G30 P13 X54.04 Y-31.2 H0 Z-99999
        G30 P14 X-54.04 Y-31.2 H0 Z-99999
        G30 P15 X0 Y0 H0 Z-99999 S6
        ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
        ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
        homedelta.g
        In my home routine I have an initial bump, then a move away from the hard end-stop and another slower bump with appropriate currents and sensitivity for both to function flawlessly outside of the call from "M915 X Y Z S3 F0 R3" after a stall.
        The trouble seems to come on the second bump where, as far as I can tell, Y tower is skipping or something strange is happening.
        EDIT: after closer observation the stall on first bump does not work and indeed the homing routine is not carried out properly past the first bump regardless of my settings for current or sensitivity while called by R3 of M915.
        ; homedelta.g
        G91					                    ; use relative positioning
        ;M400					                ; make sure everything has stopped before we make changes
        M915 X Y Z S3 F0 R0                     ;set stall detect drives, S-threshold (-64 to 63), F1 filtered, R 0 = no action (default), 1 = just log it, 2 = pause print, 3 = pause print, execute /sys/rehome.g, and resume print
        M201 X800 Y800 Z800                     ; set max acceleration
        M913 X32 Y32 Z32		               	; reduce motor current to 32% to prevent belts slipping
        G1 H1 X12000 Y12000 Z12000 F4500		; move all carriages up 12000mm, stopping at the endstops
        M913 X100 Y100 Z100			            ; motor currents back to normal
        M201 X4000 Y4000 Z4000                  ; set max acceleration
        G1 H2 X-20 Y-20 Z-20 F15000				    ; down a few mm so that we can home again slowly
        M915 X Y Z S2 F0 R0                     ;set stall detect drives, S-threshold (-64 to 63), F1 filtered, R-do nothing
        M913 X29 Y29 Z29		               	; reduce motor current to 25% to prevent belts slipping
        G1 H1 X12000 Y12000 Z12000 F2600		; move all carriages up 12000mm, stopping at the endstops
        G90					                    ; back to absolute positioning
        M915 X Y Z S3 F0 R3                     ;set stall detect drives, S-threshold (-64 to 63), F1 filtered
        rehome.g
        SAME AS HOMEDELTA.G although it functioned poorly as simply G28 as well
        Again, only strange on a call from the stall detection home on skipped steps of M915 with R3
        pause.g
        ; pause.g
        ; called when a print from SD card is paused
        M83            ; relative extruder moves
        G1 E-20 F3600  ; retract 10mm of filament
        G91            ; relative positioning
        G1 Z150 F3600     ; lift Z by 5mm
        G90            ; absolute positioning
        G1 X0 Y0 F3600 ; go to X=0 Y=0
        Thanks for reading all the way down here....hope you have an idea on this one....what am I missing?
