    Missing IO_0 on 3HC online config tool
    Config Tool
    • -Jules- 0undefined
      -Jules- 0
      Hi guys,
      after years of running a delta with repetier and never been able to get the bed level (always some deviation around +- 0.1 or even worse) i decided to switch to duet.
      So im currently in te middle of my build with the duet3 mini 5 and expension board (love it) but on checking the online configuration i cant select board1.IO_0 (1 to 5 are there)
      maybe im missing something?
      if this isnt the way to post this kind of missing things, let me know, first time posting here 😊
      There’s No Place Like 127.0.0.1
        Good question. Will see about that. In the meantime you can choose io1 and then edit the config.g after you've got it in place using the web interface to use io0.
