    IDEX/Z - Tool change (Separate print and mill heads)
    CNC
    general
    • PARRSundefined
      PARRS
      Hi all. I'm new to the forum so please forgive me if some of my questions have been answered or if I am going about posting wrong.
      Machine summary: Currently utilizing a duet 3 to control a cartesian style build with 2 independent X carriages that have independent Z axis. One Carriage houses a router/mill and the other has a printing head. Planning to use the mill to clean up prints.
      Please see my config and tool change macros for additional information.
      config.g homeall.g tfree0.g tfree1.g tpre0.g tpre1.g
      My problem lies with switching between tools and homing macros. As of now I am capable of using the mill head and print head independently with XYZ inputs (I switch drive mapping with tool change macros while ensuring the locations are preserved by performing a "park" cycle, and using G92 to write the known locations when switching from tool to tool).
      My main problems at this point are when I switch to T1 (mill) and perform a homeall, the system hangs up on the tool change (I have switch to T0 as my first command so that the correct steppers and end stops are being controlled). I tried implementing M116 in the thoughts that the switch between tools wasn't happening fast enough...
      My next issue is that since T0 is a print head, I would like the system to be in FFF print mode when in use; however, when in print mode my homeall function falls apart and the T0 Z axis plunges into the table rather than the lift until end stop is hit (like it does in CNC mode).
      I am going about it this way as I intend on using Fusion 360 to post the code, however it only lets me utilize XYZ axis (hence the need for remaps when switching between mill and print)
      chiefmonkeyundefined 1 Reply Last reply Reply Quote 0
      • chiefmonkeyundefined
        chiefmonkey @PARRS
        @parrs
        This might make it a bit easier to read, just imbedded your code
        config.g
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 10 2020 12:31:28 GMT-0600 (Mountain Daylight Time)
        G90        ; send absolute coordinates...
        M83        ; ...but relative extruder moves
        M550 P"Duet3"  														 ; sets printer name
        M453  																 ; sets CNC mode
        M569 P0.0 S0                                                         ; physical drive 0.0 goes reverse
        M569 P0.1 S1                                                         ; physical drive 0.1 goes forwards
        M569 P0.2 S1                                                         ; physical drive 0.2 goes forwards
        M569 P0.3 S0                                                         ; physical drive 0.3 goes reverse
        M569 P0.4 S0                                                         ; physical drive 0.4 goes reverse
        M569 P0.5 S1                                                         ; physical drive 0.5 goes forwards
        M569 P1.0 S1                                                         ; physical drive 1.0 goes forwards
        M569 P1.1 S1                                                         ; physical drive 1.1 goes forwards
        M569 P1.2 S1                                                         ; physical drive 1.2 goes forwards
        M569 P2.1 S1                                                         ; physical drive 2.1 goes forwards
        M569 P2.2 S0                                                         ; physical drive 2.2 goes forwards
        M584 X0.0 Y0.1:0.2 Z0.4 U0.3 V0.5 B2.2 E1.0				             ; set drive mapping
        M350 X32 Y32 Z64 U32 V64 B32 E16 I1                                  ; configure microstepping with interpolation
        M92 X800.00 Y795.9565 Z1592.718 U800.0 V1592.718 B70 E1000    		 ; set steps per mm
        M566 X800.00 Y800.00 Z800.00 U800.00 V800.00 B1000.00 E8000.00       ; set maximum instantaneous speed changes (mm/min)
        M203 X3000.00 Y3000.00 Z3000.00 U3000 V3000 B30000.00 E10000.00 	 ; set maximum speeds (mm/min)
        M201 X200.00 Y200.00 Z200.00 U200.00 V200.00 B500.0 E250.00          ; set accelerations (mm/s^2)
        M906 X2000 Y2000 Z2000 U2000 V2000 B2000 E1800  I100                 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                                              ; Set idle timeout
        M208 X85 Y0 Z0 U0 V0 B-500000 S1                                     ; set axis minima
        M208 X677 Y810 Z187.6 U615 V200 B500000 S0                           ; set axis maxima.  z default with 5/8 spoil board 190.
        M574 X2 S1 P"!io0.in"                                        ; configure active-high endstop for low end on X via pin io0.in
        M574 Y1 S1 P"!io1.in+!io2.in"                                ; configure active-high endstop for low end on Y via pin io1.in
        M574 Z2 S1 P"!io4.in"                                        ; configure active-high endstop for high end on Z via pin io2.in
        M574 U1 S1 P"!io3.in"                                        ; configure active-high endstop for high end on U via pin io2.in
        M574 V2 S1 P"!io5.in"                                        ; configure active-high endstop for high end on V via pin io2.in
        M558 P0 H5 F120 T6000                                        ; disable Z probe but set dive height, probe speed and travel speed
        M557 X15:215 Y15:195 S20                                     ; define mesh grid
        //M308 S0 P"temp0" Y"pt1000" R2200                           ; configure sensor 0 as PT1000 on pin temp0
        //M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
        //M307 H0 B0 S1.00                                           ; disable bang-bang mode for the bed heater and set PWM limit
        //M140 H0                                                    ; map heated bed to heater 0
        //M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
        //M308 S1 P"1.temp2" Y"thermistor" T100000 B4138             ; configure sensor 1 as thermistor on pin 1.temp2
        //M950 H1 C"!out1" T1                                        ; create nozzle heater output on !out1 and map it to sensor 1
        //M307 H1 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
        //M950 F0 C"!out4" Q500                                      ; create fan 0 on pin !out4 and set its frequency
        //M106 P0 S0 H-1                                             ; set fan 0 value. Thermostatic control is turned off
        //M950 F1 C"!out3" Q500                                      ; create fan 1 on pin !out3 and set its frequency
        //M106 P1 S1 H-1 										  	 ; set fan 1 value. Thermostatic control is turned off
        M563 P0 S"Extruder" D0 F0                 					 ; define tool 0
        G10 P0 X0 Y0 Z0                                              ; set tool 0 axis offsets
        G10 P0 R0 S0                                                 ; set initial tool 0 active and standby temperatures to 0C
        M563 P1 S"Mill" F0 ;X3                                        ; define tool 1 (U axis mapped to X axis)
        G10 P1 X0 Y0 Z0                                              ; set tool 1 axis offsets
        G10 P1 R0 S0                                                 ; set initial tool 1 active and standby temperatures to 0C
        ;Spindle
        M453 S0 C"out9" R12000 T1 F100								 ; creates spindle S0 sets PWM out to pin 9
        ;Original code above
        ;//M563 P1 S"Mill" D1 F0                                     ; define tool 1
        ;//G10 P1 X0 Y0 Z0                                           ; set tool 1 axis offsets
        ;//G10 P1 R0 S0
        M501                                                         ; load saved parameters from non-volatile memory
        homeall.g
        ; homeall.g
        ; called to home all axes
        T0
        M116
        G91                     		; relative positioning
        G1 H1 Z200 F1200       			; move Z up stopping at the endstop
        G1 H1 V200 F1200       			; move V up stopping at the endstop
        G1 H2 Z-10 V-10 F6000 			; go back a few mm
        G92 Z187.6 V195               	; set Z and V position to axis minimum (you may want to adjust this)
        G1 H2 Z5 V5 F6000          		; lift Z and V relative to current position
        G1 H1 X+705 Y-816 U-705 F1800 	; move quickly to X and Y axis endstops and stop there (first pass)
        G1 H2 X-5 Y5 U5 F6000       	; go back a few mm
        G1 H1 X+705 Y-816 U-705 F360  	; move slowly to X and Y axis endstops once more (second pass)
        G90                     		; absolute positioning
        G92 B0							; Set position - B axis (rotary) to 0
        ;T0
        ;G91                    		; relative positioning
        ;G1 Z5 F100             		; lift Z relative to current position
        ;G90                    		; absolute positioning
        tfree0.g
        ; Operations to be done before switching from T0 to T1 (EXTRUDER TO MILL)
        ;TOOL ZERO MOVEMENTS (EXTRUDER)
        G90				;ABSOLUTE COORDINATES
        G1 Z185			;LIFT Z TO PARK LOCATION
        G1 X675			;MOVE X TO PARK LOCATION (FAR RIGHT OF MACHINE)
        tfree1.g
        ;Operations to be done before switching from T1 to T0
        ;DO THESE NEED TO BE X AND Z VALUES OR U AND V??????????????????
        G90				;ABSOLUTE MOVEMENTS
        G1 Z185			;LIFT T1
        G1 X0			;MOVE T1 TO PARK POSITION (LEFT SIDE OF MACHINE)
        ;THESE VALUES NEED TO MATCH TPRE1.G PARK VALUES AS THE MACHINE OVERWRITES TOOL LOCATION WHEN SWITCHING. NEEDS TO KNOW WHERE IT IS
        tpre0.g
        ;Operations/configurations to be set when T0 selected - NOTE THIS OVERRIDES THE CONFIG.G PARAMETERS AFTER SWITCHING TOOLS
        ;NOTE: ENDSTOPS HAVE NOT BEEN RECONFIGURED FROM CONFIG.G - MAY NEED TO BE
        ;M451						;SET TO FFF PRINT MODE
        M584 X0.0 Z0.4 U0.3 V0.5	;SET DRIVE MAPPING (EXT NOW CONTROLLED BY X AND Z COMMANDS) - REMAP T1 TO U&V
        M350 X32 Z64				;SET MICROSTEPPING
        M92 X800 Z1592.718 			;SET STEPS/MM (VALUE NEEDED FOR MILL Z AXIS - REMEMBER MILL AND EXTRUDER MAY BE DIFFERENT) **UPDATE**
        M566 X800 Z800 				;SET INSTANTANEOUS SPEED CHANGES (MM/MIN)
        M203 X3000 Z3000 			;SET MAXIMUM SPEEDS (MM/MIN)
        M201 X200 Z200 				;SET ACCELERATION (MM/S^2)
        M208 X85 S1					;SETS AXIS MINIMUM (MAKE IT SO IT WONT COLLIDE WITH MILL) S1 DENOTES MIN WHERE S0 OR BLANK DENOTES MAX
        M208 X677
        G92 X675 Z185				;SET POSITION - SET TO MATCH PARK VALUES (TFREE0.G) SO SOFTWARE KNOWS WHERE TOOL IS AFTER SWITCHING
        tpre1.g
        ;Operations/configurations to be set when T1 selected - NOTE THIS OVERRIDES THE CONFIG.G PARAMETERS AFTER SWITCHING TOOLS
        M453					;SET TO CNC MODE
        M584 X0.3 Z0.5			;SET DRIVE MAPPING (MILL NOW CONTROLLED BY X AND Z COMMANDS)
        M208 X0 S1				;SETS AXIS MINIMUM (S1 DENOTES MINIMUM WHERE S0 OR BLANK DENOTES MAX)
        M208 X615				;SETS AXIS MAXIMUM (ENSURE CLEARANCE IS MAINTAINED IN RESPECT TO T0 IN PARK LOCATION)
        G92 X0 Z185				;SET POSITION - SET TO MATCH PARK VALUES (TFREE1.G) SO SOFTWARE KNOWS WHERE TOOL IS AFTER SWITCHING
