    M906 max A with 1 or 2 phases max energized?
    Using Duet Controllers
    • A Former User?
      A Former User
      Hi everyone,
      just shot a nice stepper-motor on da "bay", which I would like to test with a duet3 (bigboard, not the new mini) and now a bit puzzled how to set the M906 for it...
      • here is a piece of the datasheed regarding the stepper-specifications:
      And now the question is M906 setting the max A with 2phases or 1phases max energized?
      I assume the statement (https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents)"^3 Divide by 1.414 for RMS current as used in Marlin implementations for Trinamic drivers" means that duet´s M906 uses 2phases-energized, what would be in my case those 3.7A (of course *0.9... to keep that thing cool running)?
      Help welcomed!
      Best regards
        dc42 administrators @A Former User
        @lbi said in M906 max A with 1 or 2 phases max energized?:
        With 1 phase energised. RRF has always used peak current. Marlin versions generally use RMS current for Trinamic drivers, but peak current for other makes of driver.
        • A Former User?
          A Former User @dc42
          Thanks! As usual 🙂
          So I got it the wrong way round: RRF uses Peak-A and marlin uses RMS-A
          Thanks!
