    Klipper on Duet 3 6HC
    Firmware installation
    1.0k
    • Andrey 0undefined
      Andrey 0
      Hello everyone! How to install a klipper firmware on the duet 3 6hc? It is documentation for duet 3 mini https://github.com/KevinOConnor/klipper/pull/4133? Why after all update config files the klipper give error
      "Creating symbolic link out/board
      warning: the choice symbol MACH_SAME70 (defined at src/atsam/Kconfig:2, src/atsam/Kconfig:38, src/atsam/Kconfig:53) is selected by the following symbols, but select/imply has no effect on choice symbols
      • MACH_SAME70 (defined at src/atsam/Kconfig:2, src/atsam/Kconfig:38, src/atsam/Kconfig:53)
        warning: the choice symbol MACH_SAME70 (defined at src/atsam/Kconfig:2, src/atsam/Kconfig:38, src/atsam/Kconfig:53) is defined with a prompt outside the choice
        lib/kconfiglib/menuconfig.py: Dependency loop
      MACH_SAME70 (defined at src/atsam/Kconfig:2, src/atsam/Kconfig:38, src/atsam/Kconfig:53), with definition...
      config MACH_SAME70
      bool "SAME70Q20 (Duet3 6HC)"
      select MACH_SAME70
      config MACH_SAME70
      select MACH_SAME70
      depends on <choice>
      config MACH_SAME70
      bool
      depends on MACH_ATSAM
      (select-related dependencies: MACH_SAME70 || (MACH_SAME70 && <choice>))
      ...depends again on MACH_SAME70 (defined at src/atsam/Kconfig:2, src/atsam/Kconfig:38, src/atsam/Kconfig:53)
      make: *** [Makefile:112: menuconfig] Error 1".
      Please tell me.
      lukeslaboratory opened this pull request in KevinOConnor/klipper
      closed Config: Add Generic-Duet3-Mini.cfg Board Config #4133
      droftartsundefined Andrey 0undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Andrey 0
        @andrey-0 it will be better for you to ask on the Klipper discord server. A few users on this forum use Klipper, and you are free to discuss it here, but generally we don’t have much experience using it, and Duet3D does not support it.
        • Andrey 0undefined
          Andrey 0 @Andrey 0
          @andrey-0 I understand, but this forum is bigger
          Andrey 0undefined 1 Reply Last reply Reply Quote 0
          • Andrey 0undefined
            Andrey 0 @Andrey 0
            @andrey-0 Hello everyone. Who knows, please write.
