    Incorrect behaviour
    Using Duet Controllers
    450
    • LeviaChanundefined
      LeviaChan
      This is my first post, sorry for the formatting and thanks for reading in advance.
      I am using a duet 2 wifi with the latest version of firmware(Release 3.3 beta 3)
      List of problem:
      1. When X home is enforced, the x axis moved a few unit to the right and assumed itself as homed, end stop were not triggered(if the end stop is triggered manually it turns off the led on the board)
      2. When Y home is enforced, the y axis move towards the end stop correctly, hitting the end stop and keep hitting the end stop, the end stop seems triggered( based on the LED turning off on the board) but it doesn't register
      3. The part cooling fan (fan0) are not moving when set to any percentage in the web control interface
      Here is the config.g content:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Apr 28 2021 20:48:23 GMT+0100 (British Summer Time)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes backwards
      M569 P1 S1 ; physical drive 1 goes backwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X98.00 Y80.00 Z400.00 E385.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X235 Y210 Z260 S0 ; set axis maxima
      M574 Y1 S1 P"ystop" ; configure sensorless endstop for low end on Y
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:190 Y15:190 S20 ; define mesh grid
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S360 ; set temperature limit for heater 1 to 360C
      T0 ; select first tool
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @LeviaChan
        @leviachan what kind of endstop are you using? Just a switch?
        Eventually you need to define the pull-up or invert them...
        like my setup:
        M574 X1 S1 P"!xstop"                                ; configure active-high endstop for low end on X via pin !xstop
        M574 Y1 S1 P"!ystop"                                ; configure active-high endstop for low end on Y via pin !ystop
        M574 Z1 S1 P"!zstop"
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        LeviaChanundefined 1 Reply Last reply Reply Quote 0
          LeviaChan @cosmowave
          @cosmowave they are some generic microswitch from a ender 3, sorry for not mentioning those
            @leviachan what is reportet when you send M119 ? Try with and without pressed x-endstop
              @cosmowave it shows:
              "M119
              Endstops - X: at min stop, Y: not stopped, Z: no endstop, Z probe: not stopped"
              physical status: X end stop not triggered, Y end stop triggered
                @leviachan i think, you should inverting the endstops with the "!"
                  LeviaChan
                  After changing P"xstop" to P"!xstop" the x axis now correctly bump into the endstop; however the end stop trigger was ignored, which is the same as the Y axis
                    @leviachan what is in your homing macros? homeall.g, homex.g
                      @cosmowave
                      I am using the one generated from the reprapfirmware configurator
                      ; homex.g
                      ; called to home the X axis
                      G91               ; relative positioning
                      G1 H2 Z5 F6000    ; lift Z relative to current position
                      G1 H1 X-240 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 H2 X5 F6000    ; go back a few mm
                      G1 H1 X-240 F360  ; move slowly to X axis endstop once more (second pass)
                      G1 H2 Z-5 F6000   ; lower Z again
                      G90               ; absolute positioning
                      ; homey.g
                      ; called to home the Y axis
                      G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 H2 Y5 F6000    ; go back a few mm
                      G1 H1 Y-215 F360  ; move slowly to Y axis endstop once more (second pass)
                      ; called to home all axes
                      G1 H1 X-240 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-240 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-265 F360        ; move Z down stopping at the endstop
                      G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                      ;G91                    ; relative positioning
                      ;G1 Z5 F100             ; lift Z relative to current position
                      ;G90                    ; absolute positioning
                        @leviachan try once again with m119, what's reported when endstops activated?
                          @cosmowave
                          "m119
                          Endstops - X: not stopped, Y: not stopped, Z: no endstop, Z probe: not stopped"
                          Physical status:
                          X axis is at home position, led on the board is off
                          Y axis is at home position, led on the board is off
                            @leviachan try with pull-up "^"
                            M574 X1 S1 P"^!xstop"
                            M574 Y1 S1 P"^!ystop"
                              LeviaChan
                              I have realized something intresting:
                              I have switched around the X and Y endstop, changing the P"!ystop" back to P"ystop" and now the Y axis homes correctly
                              This is weird because my endstops are ladled and plugged in the board according to the official pinout(X->Y->Z)
                              I have applied the same kind of change in the X axis, unfortunately it went back to the old behaviour of moving a bit to the right and called itself homed
                                @leviachan but your axles are moving properly? when you make a move x-, then the x axle is moving towards the x endstop? and vice versa
                                  @cosmowave I have found out that I am dumb and plugged the endstop into the wrong place 😥 I am thankful for your help, the X and Y axis is homing correctly now
                                  The Z axis is refusing to home now, I will spend some time trying to fix that and post back if it goes weird again
                                  again, thanks very much for the help
                                    @leviachan eventually you have a similiar problem with the fan. Is it connected correct? And is the jumper for VFan setted properly?
                                      @cosmowave I have went back and checked, the polarity is flipped by the manufacturer, after quickly flipping the position of red and black wire it now works as intended
