    Configure Diode Laser in
    Using Duet Controllers
    1
    • Flex12undefined
      Flex12
      Hy, I recently tried to get my installed laser up and running.
      I read the following entries on the subject:
      • https://duet3d.dozuki.com/Wiki/Laser_PWM_control#Section_PWM_Circuit
      • https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_spindle_or_GPIO_servo_pin
      • https://duet3d.dozuki.com/Wiki/Gcode#Section_M452_Select_Laser_DeviceMode
      My laser is a neje "20w" (5w) diode laser connected to pwm2 on duex2 and it works quite well as an engraving tool.
      I set up my laser within a new Tool.
      My current config.g file:
      M563 P3 S"Laser"                                        	; define tool 2
      M950 P1 C"duex.pwm2"										; Allocate type of output
      M452 C"duex.pwm2" R255 F500        							; Enable Laser mode, on duex.pwm2, with max intensity being 255, and a PWM frequency of 500
      G10 P3 X0 Y0 Z0                                             ; set tool 3 axis offsets
      G10 P3 R0 S0                                                ; set initial tool 3 active and standby temperatures to 0C
      To work with the laser i typed in the console:
      M3 S255
      **or**
      G1 S100
      **or**
      M42 P"duex.pwm2" S1 (For 100% power)
      Unfortunatly not one of the commands was succesfull with activating the laser.
      If i configured the PWM signal to match the one from my bl-touch my laser begun to burn as long as the homing procedure was taking place.
      I don't understand what i can look for in this case. i could really use some hints.
      Flex12undefined 2 Replies Last reply Reply Quote 0
      • Flex12undefined
        Flex12 @Flex12
        @flex12 In RRF 3
        • Flex12undefined
          Flex12 @Flex12
          @flex12
          This is the code from 122
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX2
          Board ID: 08DLM-996RU-N85T0-6J9FL-3SD6R-1SS3N
          Used output buffers: 3 of 24 (15 max)
          Static ram: 23460
          Dynamic ram: 73900 of which 24 recycled
          Never used RAM 14696, free system stack 204 words
          Tasks: NETWORK(ready,186) LASER(blocked,67) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,625) IDLE(ready,20)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:13:33 ago, cause: software
          Last software reset at 2021-05-02 21:56, reason: User, GCodes spinning, available RAM 14452, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 36.3, current 36.8, max 37.8
          Supply voltage: min 0.2, current 0.4, max 2.0, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available
          Driver 1: position 0, ok, SG min/max not available
          Driver 2: position 0, ok, SG min/max not available
          Driver 3: position 0, ok, SG min/max not available
          Driver 4: position 0, ok, SG min/max not available
          Driver 5: position 0, ok, SG min/max not available
          Driver 6: position 0, ok, SG min/max not available
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-05-02 22:09:51
          Cache data hit count 1135360814
          Slowest loop: 7.13ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.9ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.76ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address 84:0d:8e:b2:f6:52
            WiFi Vcc 3.33, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 25600
            WiFi IP address 192.168.0.102
            WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            === DueX ===
            Read count 1, 0.07 reads/min
