3.0 Heater/Fan configuration
@zemlin said in 3.0 Heater/Fan configuration:
I'm not exactly sure what triggers the change, but when I went to run a part, the hot-end fan doesn't start up - but in the Dashboard Fan2 appears, and the slider appears to override the thermostatic control and the fan doesn't run.
By "run a part", do you mean run a print job from SD card? If so, then perhaps something in the print job is reconfiguring the fan - in which case, please share the print file.
I really appreciate all the help.
I changed the can lines per @DIY-O-Sphere toM950 F1 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P1 S1 H1 T40 ; set fan 2 value. Thermostatic control is turned on Functioning properly and not showing up on the dashboard slider.
The Z-Probe on this machine is accelerometer-based and that's a little flaky, but doesn't seem to be software related.Up and running now, so 'til next time ...
