    3.3RC1 Duet2 SBC Problems with Bltouch
    Beta Firmware
    949
    • lahn92undefined
      lahn92
      Hey
      i have recently upgraded to Duet 2 wifi running in SBC mode (Raspberry Pi 3b, duetPi lite). and I'm slowly wokring my way through a few issues but atm i am having quite a lot of problems with my BlTouch.
      it deploys and retracts with M401 and M402 and also worked perfectly before with out any problems .
      but after the upgrade the printer hangs when it has to deploy and it hangs when it triggers before then retracting the probe, and sometimes during probing it will then fail and give a "probe already triggered before probing move started"
      it seems to happen mostly when running a G29, but also sometimes happens with a G30, that i use to level the x axis, how not observed it when homing z.
      my config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Mar 05 2019 15:58:37 GMT+0100 (Centraleuropæisk normaltid)
      ;3dprint counter
      M950 S4 C"duex.pwm2"								  ;heater 7 as servo pin 4
      M42 P4 S0											  ; servo pin4 set to low
      G90                                                   ; Send absolute coordinates...
      M83                                                   ; ...but relative extruder moves
      M550 P"P3sbc"                                         ; Set machine name
      M551 P"iasdf"                                         ; Set password
      ;M552 S1                                              ; Enable network
      ;M586 P0 S1                                           ; Enable HTTP
      ;586 P1 S0                                            ; Disable FTP
      ;586 P2 S0                                            ; Disable Telnet
      M584 X0 Y8 E1 V3 W7 U9 Z2:4                           ; two Z motors connected to driver outputs Z and E1
      M569 P0 S1                                            ; Drive 0 goes forwards
      M569 P1 S0                                            ; Drive 1 goes forwards
      M569 P2 S1                                            ; Drive 2 goes forwards
      M569 P3 S1                                            ; Drive 3 goes forwards
      M569 P4 S1                                            ; Drive 4 goes forwards
      M569 P8 S0                                            ; Drive 8 goes backwards  V
      M569 P9 S0                                            ; Drive 9 goes forwards   U
      M569 P7 S1                                            ; Drive 7 goes forwards   W
      M350 X16 Y16 V16 U16 W16 Z16 E16 I1                                         ; Configure microstepping without interpolation                                                             ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E409.0 U400 V162 W26                          ; Set steps per mm
      M566 X300.00 Y300.00 Z36.00 E240.00 U200 V3600 W300                      ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z1200.00 E7200.00 U2600 V7000 W9000           ; Set maximum speeds (mm/min)
      M201 X1300.00 Y1300.00 Z120.00 E3000.00 U500 V900 W900                  ; Set accelerations (mm/s^2)
      M906 X1500.00 Y1500.00 Z800.00 E1250.00 U750 V1000 W750 I30             ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 				                                                       ; Set idle timeout
      ;Duel z compensation
      M671 X-55:296 Y0:0 S5                                 ; leadscrews at left (connected to Z) and right
      M208 X-8 Y-5 Z0 U0 V-1000 W0 S1                       ; Set axis minima
      M208 X237 Y215 Z200 U75 V1000 W78 S0                  ; Set axis maxima
      ; Stall detection
      M915 X Y U V W S20 R0 F1
      M574 X1 Y1 S3                                         ; Set endstops controlled by motor load detection
      M574 U2 W1 S3
      M574 Z1 S2                                            ; Set endstops controlled by probe
      M574 V1 P"e0stop" S1
      ;Filament sensor
      M591 D0 P1 C"xstop" S0
      ;led setup
      M950 P2 C"e1heat" Q500
      M42 P2 I1 S1				                          ; set lighting on full bright
      M950 S0 C"duex.pwm1"                                  ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H10 F320 T9000                   ; Set Z probe type to bltouch and the dive height + speeds
      G31 P900 X-14.65 Y19,29 Z3.24                         ; Set Z probe trigger value, offset and trigger height
      M557 X20:222 Y15:215 S30                              ; Define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 A"Bed" ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                 ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 A109.9 C411.9 D9.6 V11.7 B0 S1.00             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                               ; map heated bed to heater 0
      M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
      M308 S1 P"spi.cs1" Y"rtd-max31865" A"Hotend"          ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
      M950 H1 C"e0heat" T1                                  ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 A354.8 C196.4 D4.3 V12 B0 S1.00               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S400                                          ; Set temperature limit for heater 1 to 400C
      M308 S2 Y"drivers" A"Drivers"
      M950 F0 C"fan0" Q500                                  ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Part Cooler"                         ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                  ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45 C"Heatsink Cooler"                  ; set fan 1 value. Thermostatic control is turned on
      ;Tools
      M563 P0 D0 H1                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
      M563 P1 D0 H1                                      ; Define tool 1
      G10 P1 X0 Y0 Z0	                                   ; Set tool 1 axis offsets
      G10 P1 R0 S0                                       ; Set initial tool 1 active and standby temperatures to 0C
      M563 P2 D0 H1                                      ; Define tool 2
      G10 P2 X0 Y0 Z0                                    ; Set tool 2 axis offsets
      G10 P2 R0 S0 					                   ; Set initial tool 2 active and standby temperatures to 0C
      M563 P3 D0 H1                                      ; Define tool 3
      G10 P3 X0 Y0 Z0                                    ; Set tool 3 axis offsets
      G10 P3 R0 S0 					                   ; Set initial tool 3 active and standby temperatures to 0C
      M563 P4 D0 H1                                      ; Define tool 4
      G10 P4 X0 Y0 Z0                                    ; Set tool 4 axis offsets
      G10 P4 R0 S0 					                   ; Set initial tool 4 active and standby temperatures to 0C
      ;LCD screen setup
      M575 P1 S1 B57600
      ;Global varibels
      global purgeLoc = 0
      ;retraction setup
      ;M207 P0 S0.8 F3000 Z0.2								  ;basic Retraction setup
      ; M911 S10.7 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-1 F1000"
      T-1 P0
      also an M122
      M122
      RepRapFirmware for Duet 2 SBC version 3.3RC1 (2021-05-01 09:58:40) running on Duet 2 1.02 or later + SBC + DueX5 (SBC mode)
      Board ID: 08DGM-9T6BU-FG3S8-6J1DJ-3SN6M-1SLBG
      Used output buffers: 1 of 24 (24 max)
      Static ram: 17420
      Dynamic ram: 63480 of which 0 recycled
      Never used RAM 30660, free system stack 104 words
      Tasks: SBC(resourceWait:,57.5%,297) HEAT(delaying,0.5%,331) Move(notifyWait,2.3%,305) DUEX(notifyWait,0.0%,24) MAIN(running,39.7%,374) IDLE(ready,0.1%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 01:23:27 ago, cause: power up
      Last software reset at 2021-05-08 17:13, reason: User, none spinning, available RAM 30660, slot 0
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 44.9, current 49.4, max 50.4
      Supply voltage: min 11.4, current 11.6, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/140/128, gc cycles 0
      Driver 0: position 9723, ok, SG min/max 0/1023
      Driver 1: position 8541, ok, SG min/max 0/1023
      Driver 2: position 1760, standstill, SG min/max 57/344
      Driver 3: position 400, standstill, SG min/max 0/1023
      Driver 4: position 1620, standstill, SG min/max 0/333
      Driver 5: position 2028, standstill, SG min/max not available
      Driver 6: position 0, standstill, SG min/max not available
      Driver 7: position 0, standstill, SG min/max 0/846
      Driver 8: position 0, ok, SG min/max 0/1023
      Driver 9: position 0, standstill, SG min/max 0/1023
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-05-08 18:43:13
      Slowest loop: 735.06ms; fastest: 0.10ms
      DMs created 83, maxWait 535188ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 6335, completed moves 6320, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.5
      Heater 1 is on, I-accum = 0.7
      Segments left: 1
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is doing "G1 X123.866997 Y100.974998 F7800.000000" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: no filament
      === DueX ===
      Read count 1, 0.01 reads/min
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 5ms ago
      RX/TX seq numbers: 49622/49622
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x0d08c
      Buffer RX/TX: 976/2432-0
      === Duet Control Server ===
      Duet Control Server v3.3-rc1
      File:
      Buffered code: G1 X123.867 Y100.975 F7800.000
      Buffered code: G1 F900.000
      Buffered code: G1 X113.132 Y100.975 E0.32706
      Buffered code: G1 X113.132 Y97.539 E0.10467
      Buffered code: G1 X123.867 Y97.539 E0.32706
      Buffered code: G1 X123.867 Y100.915 E0.10284
      Buffered code: G1 X124.275 Y101.382 F7800.000
      Buffered code: G1 X112.725 Y101.382 E0.35186
      Buffered code: G1 X112.725 Y97.132 E0.12947
      Buffered code: G1 X124.275 Y97.132 E0.35186
      Buffered code: G1 X124.275 Y101.322 E0.12764
      Buffered code: G1 X123.877 Y101.335 F7800.000
      Buffered code: G1 X114.487 Y98.068
      Buffered code: G1 F2100.000
      Buffered code: G1 X113.844 Y98.711 E0.02781
      Buffered code: G1 X113.844 Y99.289 E0.01767
      Buffered code: G1 X114.882 Y98.252 E0.04488
      Buffered code: G1 X115.460 Y98.252 E0.01767
      Buffered code: G1 X113.844 Y99.867 E0.06987
      Buffered code: G1 X113.844 Y100.263 E0.01210
      Buffered code: G1 X114.026 Y100.263 E0.00558
      Buffered code: G1 X116.037 Y98.252 E0.08698
      Buffered code: G1 X116.615 Y98.252 E0.01767
      Buffered code: G1 X114.604 Y100.263 E0.08698
      Buffered code: G1 X115.182 Y100.263 E0.01767
      Buffered code: G1 X117.193 Y98.252 E0.08698
      Buffered code: G1 X117.771 Y98.252 E0.01767
      Buffered code: G1 X115.760 Y100.263 E0.08698
      Buffered code: G1 X116.338 Y100.263 E0.01767
      Buffered code: G1 X118.349 Y98.252 E0.08698
      Buffered code: G1 X118.927 Y98.252 E0.01767
      ==> 1480 bytes
      Code buffer space: 1664
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 35.70
      Codes per second: 6.35
      Maximum length of RX/TX data transfers: 3808/1580
      File /opt/dsf/sd/gcodes/s-buffer-spacer.gcode is selected, processing
      Phaedruxundefined 1 Reply Last reply Reply Quote 1
      • lahn92undefined
        lahn92
        so i made a quick video that shows, a z home, x-axis level, and a G29 that shows they way it hangs at times
        it also ends failing the G29
        https://www.youtube.com/watch?v=p5xrNgZ7IoQ
        the error the paneldue show, i have not seen before as i so far have only seen DWC in a browser that shows, ""probe already triggered before probing move started""
          Phaedrux Moderator @lahn92
          @lahn92 said in 3.3RC1 Duet2 SBC Problems with Bltouch:
          Not sure if it matters but it looks like you're using a comma instead of a period in Y19,29
          You can send G31 by itself in the console to see what it has interpreted the value as.
          Also, for the BLtouch try G31 P25. And your dive height is a bit high. Try M558 H5. And dive speed a bit fast. Try M558 F120.
          lahn92undefined 1 Reply Last reply Reply Quote 0
          • lahn92undefined
            lahn92 @Phaedrux
            @phaedrux
            my dive hight and speed was normally what you sugested but changed it trying to diagnose the problem.
            but i have changed it back now to test
            also changed the G31
            M558 P9 C"^zprobe.in" H5 F120 T9000                   ; Set Z probe type to bltouch and the dive height + speeds
            G31 P25 X-14.65 Y19.29 Z3.24                         ; Set Z probe trigger value, offset and trigger height
            it homed z fine, ran G29 2 times and both times it failed within the first 5 probes
            Edit: just had it happen on a z-axis home
            M122 from right after
            M122
            Used output buffers: 1 of 24 (23 max)
            Static ram: 17420
            Dynamic ram: 63144 of which 0 recycled
            Never used RAM 30996, free system stack 126 words
            Tasks: SBC(ready,13.4%,291) HEAT(delaying,0.1%,331) Move(notifyWait,0.2%,305) DUEX(notifyWait,0.0%,24) MAIN(running,86.3%,479) IDLE(ready,0.0%,30), total 100.0%
            Last reset 02:04:30 ago, cause: power up
            Last software reset at 2021-05-09 07:30, reason: User, none spinning, available RAM 30788, slot 1
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU temperature: min 31.8, current 38.1, max 38.6
            Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/24/12, gc cycles 0
            Driver 0: position 9600, standstill, SG min/max 0/301
            Driver 1: position 8800, standstill, SG min/max not available
            Driver 2: position 3296, standstill, SG min/max 65/299
            Driver 4: position 0, standstill, SG min/max 0/293
            Driver 5: position 0, standstill, SG min/max not available
            Driver 7: position 0, standstill, SG min/max not available
            Driver 8: position 0, standstill, SG min/max 0/634
            Driver 9: position 0, standstill, SG min/max not available
            Date/time: 2021-05-09 09:40:37
            Slowest loop: 784.16ms; fastest: 0.09ms
            DMs created 83, maxWait 7403072ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 6, completed moves 6, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            File is idle in state(s) 0
            Queue is idle in state(s) 0
            === DueX ===
            Last transfer: 4ms ago
            RX/TX seq numbers: 61060/61060
            Buffer RX/TX: 0/0-0
            Daemon:
            Finishing macro daemon.g, started by system
            > Next stack level
            Code buffer space: 4096
            Full transfers per second: 34.10
            Codes per second: 0.12
            Maximum length of RX/TX data transfers: 3632/700
            • nmsmith89undefined
              nmsmith89
              I have the exact same problem and for the life of me I can't figure it out.
              I'm running a Duet 3 Mini 5+ in SBC mode. Also have the BLTouch connected to a Toolboard 1LC.
              I've checked the wiring and everything and it all seems fine. Diving faster seems to help a little bit but doesn't solve the problem.
              From what I can tell it's the combination of 2 factors that causes the problem to happen:
              1. The BLTouch will go into error mode of it sits triggered for too long. Something like more than 750ms or around there. As far as I can tell this behaviour is intended.
              2. At least with my setup, when probing and the BLTouch is triggered there seems to be a random amount of time before the printer reacts to the trigger. Sometimes it's almost right away and sometimes it's a little bit of a pause.
              When the printer pauses long enough after a probe trigger, the delay causes the probe to go into error mode.
              I don't have any idea how to fix it but this is at least my working theory so far. It's possible it may have something to do with SBC mode. Our printers both have that in common. Maybe the presence of the SBC/Pi introduces a slight delay in between commands and/or reactions.
              @dc42 should be able to tell us if a delay does exist in SBC mode and if, per my theory, that could pose a problem for the BLTouch in some specific setups.
              • lahn92undefined
                lahn92
                @nmsmith89
                interresting, i was thinking it was something more to do with it being duet 2 and sbc
                  Phaedrux Moderator @nmsmith89
                  @nmsmith89 In your case I think this is a known limitation in RRF3.
                  Endstop switches and Z probes connected to the main board cannot control motors on an expansion board. This is planned to be fixed in release 3.4.
                  If you use a Z probe then the Z motors must be connected to the main board. This is planned to be fixed in release 3.4.
                  https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
                  @lahn92 you're using a Duet2 modded to use the SBC connector, so I'm not sure how that limitation would affect you if at all. Will check.
                  • lahn92undefined
                    lahn92 @Phaedrux
                    @phaedrux
                    so tried removing my PT100 sensor and paneldue from my config to see if that was making somekind of problem.
                    it did not help.
                    busy grasping at straws here 😉
                      dc42 administrators @lahn92
                      @lahn92 and @nmsmith89, the only reason I can think of why the Z probe triggering might be detected late is if either the BLTouch has a lot of leakage when it is triggered, or there is a lot of interference picked up by the BLTouch output wire (e.g. from an adjacent stepper motor cable); and the internal pullup resistor on the zprobe.in pin isn't sufficient to counter the interference or leakage.
                      Here are two possible solutions:
                      1. If your Duet 2 is version 1.04 then you can send a command to the BLTouch to pull the output to 5V when triggered, instead of relying on the pullup resistor.
                      2. You could connect an external pullup resistor between Z probe in and +3.3V pins. I suggest a value between 2.2K and 10K.
                      The limitation referred by @Phaedrux only applies to CAN-connected expansion boards.
                      • lahn92undefined
                        lahn92 @dc42
                        any instructions on doing number 1. as i at the moment i dont have a resistor handy?
                        edit:
                        is it this
                          @lahn92 yes it's that. The Duet 2 1.04 and later can tolerate 5V input from the BLTouch.
                          • lahn92undefined
                            lahn92 @dc42
                            @dc42 Tried it, it did not change anything.
                            but i think the problem lies in deployment and retraction of the probe
                            because if io do a repeatability test with the following code it does not hang anywhere. as it does not deploy and retract the probe between touch off.
                            M291 P"Probe will be tested 10 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                            M401
                            G28 Z
                            G30 P0 X100 Y101 Z-9999
                            G30 P9 X100 Y101 Z-9999 S-1
                            M402
                            is there maybe a way to get it to not retract and deploy the probe between each point in a G29, as a quick fix solution?
                              Yes, if you use P8 instead of P9 in the M558 command then it will do that. But that may fail, because after triggering the probe will extend immediately again; and if the Z axis is not fast enough then it may trigger immediately and go into the error state.
                              lahn92undefined 2 Replies Last reply Reply Quote 0
                              • lahn92undefined
                                lahn92 @dc42
                                @dc42 Will try that tomorrow
                                • lahn92undefined
                                  lahn92 @dc42
                                  so i have tried two things today.
                                  first i tried running with the probe set as P8 and this seems to work just fin.
                                  video
                                  then i tried to switch out my current BlTouch 3.1 to an older 2.2 running as a P9.
                                  this BlTouch does not have the same issue as the 3.1 but instead does a double bounce on retraction.
                                  video
                                  with both it does not seem to error out the Bltouch, but the 3.1 still seems to experience the hang up when deploying and retracting.
                                    @lahn92 please update to release 3.3RC2 from the package server.
                                    • lahn92undefined
                                      lahn92 @dc42
                                      tried updating, and after that i also tried reinstalling duetpi-lite.
                                      both have not changed my problem
                                        And confirmed that RC2 was actually flashed to the duet?
                                        • lahn92undefined
                                          lahn92 @Phaedrux
                                          @phaedrux
                                          Yup
                                          M115
                                          FIRMWARE_NAME: RepRapFirmware for Duet 2 SBC FIRMWARE_VERSION: 3.3RC2 ELECTRONICS: Duet 2 1.02 or later + SBC + DueX5 FIRMWARE_DATE: 2021-05-11 14:55:15
                                            Thanks, just wanted to make sure.
