    Setup RPi WiFi through ExecOnMCode
    DSF Development
    • oozeBotundefined
      oozeBot
      We need a way for our customers to initially setup WiFi on our printers. There are more elegant ways to accomplish this, and it does not cover all use cases, but here is what we came up with using a custom MCode, M2222, which can be input through the PanelDue.
      Here is the service code:
      [Unit]
      Description=Duet API listener for Wifi Setup
      After=duetcontrolserver.service
      Requires=duetcontrolserver.service
      [Service]
      ExecStart=/usr/local/bin/execonmcode -mCode 2222 -command "./scripts/wifi.sh %%S %%P"
      Restart=always
      RestartSec=10
      [Install]
      WantedBy=multi-user.target
      And here is the bash script which it calls:
      #!/bin/bash
      #oozeBot Wifi Setup Script - v1.0
      SSID=$1
      PWRD=$2
      FILE="/boot/wpa_supplicant.conf"
      echo "country=US" > $FILE
      echo "update_config=1" >> $FILE
      echo "ctrl_interface=/var/run/wpa_supplicant" >> $FILE
      echo "network={" >> $FILE
      echo "        ssid=\"$SSID\"" >> $FILE
      echo "        psk=\"$PWRD\"" >> $FILE
      echo "}" >> $FILE
      Usage:
      M2222 S"SSID" P"Password"
      Reboot and the RPi is now connected to WiFi! Feedback is welcome as we would like to make this a more robust solution.
      resamundefined 1 Reply Last reply Reply Quote 0
      • resamundefined
        resam @oozeBot
        @oozebot I believe this will be built in with v3.3 - see https://github.com/Duet3D/DuetSoftwareFramework/tree/v3.3-dev/src/DuetPiManagementPlugin with lots of new M-codes for such network settings.
        oozeBotundefined 1 Reply Last reply Reply Quote 1
        • oozeBotundefined
          oozeBot @resam
          @resam good thing I only spent ~30 minutes on this.. lol
