    Read Variables in DWC?
    Duet Web Control
    • oozeBotundefined
      oozeBot
      I'm curious if anyone has figured out how to read the new global variables directly into DWC's source code?
      • chrishammundefined
        chrishamm administrators @oozeBot
        @oozebot Global variables are part of the object model so you can map them from the machine/model state as well. Something like this should work in DWC:
        <template>
        {{ myVar }}
        </template>
        <script>
          computed: mapState('machine/model', { myVar: state => state.global.myVar }),
        </script>
        Duet software engineer
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @chrishamm
          @chrishamm thanks! I literally just figured it out, but the way I did it is slightly different.. same results so I guess there is no issue with this?
          myVar: state => state.machine.model.global.myVar,
            @oozebot Yes, I think that mapping should work as well.
