    additional functions with triggers
    Firmware wishlist
    • cosmowave
      cosmowave last edited by
      Hello, i'd like to ask if it is possible to add some functions to the triggers.
      • Is it possible to make a debounce function for the trigger input "M950 J"?
      • Is it possible to temporary enable/disable the trigger?
      Once again: Thanks for your work
      Mankati FSXT+, DeltaTowerV2, CBot3D
        dc42 administrators @cosmowave last edited by dc42
        @cosmowave said in additional functions with triggers:
        There is no built-in function to do this yet, however you can use conditional GCode to debounce. For example, if the trigger activates on an inactive-to-active transition of GpIn port 0 then you could use this in the trigger file:
        G4 P10  ; delay 10ms
        if sensors.gpIn[0].value = 1 ; check that the input is still high
          <your code here>
        Yes, use M581 with the correct T parameter and R-1.
        cosmowave 1 Reply Last reply Reply Quote 0
        • cosmowave
          cosmowave @dc42 last edited by
          @dc42 perfect.
          Thanks for the explanation!
