    Duet3 6HC 12V Buck Converter Broken
    Hardware dev
    12v on 24v system broken duet3 6hc
    • PrintingTuxundefined
      PrintingTux
      Hello friends,
      I wanted to upgrade from Duet 2 to Duet 3 6HC. I've created all of the adapters and started remodeling. When testing the motors, I get the following error message.
      Error: Attempt to move motors when VIN is not in range
      I run the system at 24V, this is correctly displayed under Vin, v12 shows a voltage of 1V. All LEDs except for 12V light up. Out 4-9 have no 12V Jumpers set. Therefore I suspect a problem with the Buck Down Converter U14.
      v12 1.0V
      U14_Buck_Converter
      I don't need 12V with my system, can I deactivate it? GCode, jumpers or soldering?
      I can't find additional Information in the dokumentation.
      Wiring Diagram
      Hardware Overview - 12V
      The broken module "TS30041-M000QFNR" is difficult to obtain, as is the successor "TS30042" with 2A (is it compatible?).
      It would be nice to have a replaceable fuse for this section.
      friendly regards
        The driver chips require the 12v supply to operate. It would seem U14 has failed.
        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
