    Solved RRF3.3RC2+3 Errors on emergency stop
    Beta Firmware
    • TypQxQ
      TypQxQ last edited by
      Running Duet3 6HC+3HC+3HC in standalone.
      Upgraded from B3 to RC2+3 and get this errors after pressing Emergency Reset or issuing a M112.
      2021-05-24 19:55:54 [warn] Error: SendReq call from wrong task type=6013 dst=2
      2021-05-24 19:55:54 [warn] Error: Failed to switch off remote heater 1: SendReq call from wrong task type=6013 dst=2
      2021-05-24 19:55:54 [warn] Error: Failed to switch off remote heater 2: SendReq call from wrong task type=6013 dst=2
      2021-05-24 19:55:54 [warn] Error: Failed to switch off remote heater 3: SendReq call from wrong task type=6013 dst=2
      2021-05-24 19:55:54 [info] Event logging stopped
      My M122s:
      2021-05-24 20:07:47 [warn] Date and time set at power up + 00:00:03
      2021-05-24 20:07:53 [debug] === Diagnostics ===
      2021-05-24 20:07:53 [debug] RepRapFirmware for Duet 3 MB6HC version 3.3RC2+3 (2021-05-19 11:13:46) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
      2021-05-24 20:07:53 [debug] Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G
      2021-05-24 20:07:53 [debug] Used output buffers: 1 of 40 (15 max)
      2021-05-24 20:07:53 [debug] === RTOS ===
      2021-05-24 20:07:53 [debug] Static ram: 150680
      2021-05-24 20:07:53 [debug] Dynamic ram: 94604 of which 0 recycled
      2021-05-24 20:07:53 [debug] Never used RAM 108908, free system stack 200 words
      2021-05-24 20:07:53 [debug] Tasks:
      2021-05-24 20:07:53 [debug]  NETWORK(ready,25.9%,226)
      2021-05-24 20:07:53 [debug]  ETHERNET(notifyWait,0.1%,124)
      2021-05-24 20:07:53 [debug]  HEAT(delaying,0.0%,339)
      2021-05-24 20:07:53 [debug]  Move(notifyWait,0.0%,352)
      2021-05-24 20:07:53 [debug]  CanReceiv(notifyWait,0.0%,907)
      2021-05-24 20:07:53 [debug]  CanSender(notifyWait,0.0%,373)
      2021-05-24 20:07:53 [debug]  CanClock(delaying,0.0%,350)
      2021-05-24 20:07:53 [debug]  TMC(notifyWait,7.4%,93)
      2021-05-24 20:07:53 [debug]  MAIN(running,65.0%,924)
      2021-05-24 20:07:53 [debug]  IDLE(ready,1.4%,29)
      2021-05-24 20:07:53 [debug] , total 100.0%
      Owned mutexes:
      2021-05-24 20:07:53 [debug]  HTTP(MAIN)
      2021-05-24 20:07:53 [debug] === Platform ===
      2021-05-24 20:07:53 [debug] Last reset 00:00:09 ago, cause: software
      2021-05-24 20:07:53 [debug] Last software reset at 2021-05-24 20:07, reason: User, GCodes spinning, available RAM 108916, slot 0
      2021-05-24 20:07:53 [debug] Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      2021-05-24 20:07:53 [debug] Error status: 0x00
      2021-05-24 20:07:53 [debug] Aux0 errors 0,0,0
      2021-05-24 20:07:53 [debug] Aux1 errors 0,0,0
      2021-05-24 20:07:53 [debug] Step timer max interval 126
      2021-05-24 20:07:53 [debug] MCU temperature: min 40.7, current 41.1, max 41.2
      2021-05-24 20:07:53 [debug] Supply voltage: min 31.3, current 31.3, max 31.4, under voltage events: 0, over voltage events: 0, power good: yes
      2021-05-24 20:07:53 [debug] 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      2021-05-24 20:07:53 [debug] Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
      2021-05-24 20:07:53 [debug] Driver 0: position 0, standstill, reads 52647, writes 16 timeouts 0, SG min/max 0/0
      2021-05-24 20:07:53 [debug] Driver 1: position 0, standstill, reads 52647, writes 16 timeouts 0, SG min/max 0/0
      2021-05-24 20:07:53 [debug] Driver 2: position 0, standstill, reads 52650, writes 14 timeouts 0, SG min/max 0/0
      2021-05-24 20:07:53 [debug] Driver 3: position 0, standstill, reads 52655, writes 14 timeouts 0, SG min/max 0/0
      2021-05-24 20:07:53 [debug] Driver 4: position 0, standstill, reads 52655, writes 14 timeouts 0, SG min/max 0/0
      2021-05-24 20:07:53 [debug] Driver 5: position 0, standstill, reads 52656, writes 14 timeouts 0, SG min/max 0/0
      2021-05-24 20:07:53 [debug] Date/time:
      2021-05-24 20:07:53 [debug] 2021-05-24 20:07:53
      2021-05-24 20:07:53 [debug] Slowest loop: 4.91ms; fastest: 0.05ms
      2021-05-24 20:07:53 [debug] === Storage ===
      Free file entries: 9
      2021-05-24 20:07:53 [debug] SD card 0 detected, interface speed: 25.0MBytes/sec
      2021-05-24 20:07:53 [debug] SD card longest read time 3.0ms, write time 3.6ms, max retries 0
      2021-05-24 20:07:53 [debug] === Move ===
      2021-05-24 20:07:53 [debug] === MainDDARing ===
      2021-05-24 20:07:53 [debug] === AuxDDARing ===
      2021-05-24 20:07:53 [debug] === Heat ===
      Bed heaters =
      2021-05-24 20:07:53 [debug]  0
      2021-05-24 20:07:53 [debug]  -1
      2021-05-24 20:07:53 [debug] , chamberHeaters =
      2021-05-24 20:07:53 [debug] === GCodes ===
      2021-05-24 20:07:53 [debug] Segments left: 0
      2021-05-24 20:07:53 [debug] Movement lock held by null
      2021-05-24 20:07:53 [debug] HTTP is ready with "m122b0" in state(s) 0
      2021-05-24 20:07:53 [debug] Telnet is idle in state(s) 0
      2021-05-24 20:07:53 [debug] File is idle in state(s) 0
      2021-05-24 20:07:53 [debug] USB is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Aux is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Trigger is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Queue is idle in state(s) 0
      2021-05-24 20:07:53 [debug] LCD is idle in state(s) 0
      2021-05-24 20:07:53 [debug] SBC is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Daemon is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Aux2 is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Autopause is idle in state(s) 0
      2021-05-24 20:07:53 [debug] Code queue is empty.
      2021-05-24 20:07:53 [debug] === CAN ===
      Messages queued 146, send timeouts 0, received 208, lost 0, longest wait 1ms for reply type 6042, peak Tx sync delay 5, free buffers 49 (min 48)
      2021-05-24 20:07:53 [debug] === Network ===
      2021-05-24 20:07:53 [debug] Slowest loop: 3.39ms; fastest: 0.02ms
      2021-05-24 20:07:53 [debug] Responder states:
      2021-05-24 20:07:53 [debug]  HTTP(0)
      2021-05-24 20:07:53 [debug]  FTP(0)
      2021-05-24 20:07:53 [debug]  Telnet(0), 0 sessions
      2021-05-24 20:07:53 [debug] HTTP sessions: 1 of 8
      2021-05-24 20:07:53 [debug] - Ethernet -
      State: active
      2021-05-24 20:07:53 [debug] Error counts: 0 0 1 0 0
      Socket states:
      2021-05-24 20:07:53 [debug]  5
      2021-05-24 20:07:55 [debug] Diagnostics for board 1:
      2021-05-24 20:07:55 [debug] Duet EXP3HC firmware version 3.3RC2+2 (2021-05-17 18:05:14)
      Bootloader ID: SAME5x bootloader version 2.2 (2021-01-16b1)
      2021-05-24 20:07:55 [debug] Never used RAM 159168, free system stack 0 words
      Tasks: Move(notifyWait<null>,0.0%,160) HEAT(delaying<null>,0.0%,61) CanAsync(notifyWait<null>,0.0%,72) CanRecv(notifyWait<null>,0.0%,83) CanClock(notifyWait<null>,0.0%,74) TMC(notifyWait<null>,23.0%,63) MAIN(running<null>,75.6%,387) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,1.3%,263), total 100.0%
      Last reset 00:02:01 ago, cause: software
      2021-05-24 20:07:55 [debug] Last software reset time unknown, reason: AssertionFailed, available RAM 159320, slot 1
      Software reset code 0x0120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20004754 Task HEAT Freestk 142 bad marker
      2021-05-24 20:07:55 [debug] Stack: 00000544 0002eb94 000261af 42000400 000223e3 2002f020 00000000 2002f038 2000151c 00000000 0001d681 0002dd80 0002de38 0002d43c 000b0000 2000159c 00000000 2002f020 00015609 00000000 000009c4 000009c4 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 00024ff5
      2021-05-24 20:07:55 [debug] Driver 0: position 0, 160.0 steps/mm,  standstill, reads 38999, writes 18 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 1: position 0, 160.0 steps/mm,  standstill, reads 39002, writes 18 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 2: position 0, 80.0 steps/mm,  standstill, reads 39013, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
      2021-05-24 20:07:55 [debug] Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 6, peak Rx sync delay 175, resyncs 0, no step interrupt scheduled
      VIN: 32.1V, V12: 12.2V
      MCU temperature: min 36.5C, current 36.9C, max 36.9C
      Ticks since heat task active 80, ADC conversions started 121514, completed 121514, timed out 0, errs 0
      2021-05-24 20:07:55 [debug] Last sensors broadcast 0x00000000 found 0 86 ticks ago, loop time 0
      CAN messages queued 533, send timeouts 0, received 612, lost 0, free buffers 36, min 36, error reg 10000
      dup 0, oos 0, bm 0, wbm 0
      2021-05-24 20:07:57 [debug] Diagnostics for board 2:
      2021-05-24 20:07:57 [debug] Duet EXP3HC firmware version 3.3RC2+2 (2021-05-17 18:05:14)
      Bootloader ID: not available
      2021-05-24 20:07:57 [debug] Never used RAM 158184, free system stack 0 words
      Tasks: Move(notifyWait<null>,0.0%,160) HEAT(delaying<null>,0.0%,61) CanAsync(notifyWait<null>,0.0%,72) CanRecv(notifyWait<null>,0.0%,83) CanClock(notifyWait<null>,0.0%,74) TMC(notifyWait<null>,23.0%,63) MAIN(running<null>,75.6%,299) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,1.4%,263), total 100.0%
      Last reset 00:02:02 ago, cause: software
      2021-05-24 20:07:57 [debug] Last software reset at 2021-05-24 00:08, reason: AssertionFailed, available RAM 158184, slot 0
      Software reset code 0x0120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20004764 Task HEAT Freestk 146 ok
      2021-05-24 20:07:57 [debug] Stack: 00000544 0002eb10 000260ff 42000400 0002232f 00000000 00000020 2002f020 2000159c 00000003 0001d25b 00000000 2002f020 00000020 000157b1 00000000 00013d62 00013d62 41bae850 a5a5a5a5 a5a5a5a5 a5a5a5a5 00024f45 a5a5a5a5 00000058 00000000 2002ee70
      2021-05-24 20:07:57 [debug] Driver 0: position 0, 830.0 steps/mm,  standstill, reads 58474, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 1: position 0, 830.0 steps/mm,  standstill, reads 58477, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 2: position 0, 830.0 steps/mm,  standstill, reads 58481, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
      2021-05-24 20:07:57 [debug] Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 11, peak Rx sync delay 175, resyncs 0, no step interrupt scheduled
      VIN: 24.1V, V12: 12.2V
      MCU temperature: min 37.9C, current 38.3C, max 38.3C
      Ticks since heat task active 74, ADC conversions started 122891, completed 122890, timed out 0, errs 0
      2021-05-24 20:07:57 [debug] Last sensors broadcast 0x0000000e found 3 80 ticks ago, loop time 0
      CAN messages queued 669, send timeouts 0, received 608, lost 0, free buffers 36, min 36, error reg 110000
        dc42 administrators @TypQxQ last edited by
        @typqxq thanks for your report. This has just been fixed in the forthcoming release 3.3RC3.
        • TypQxQ
          I confirm this is fixed in 3.3RC3.
