Solved motor phase A may be disconnected reported by driver(s) 2
I have an Ender 6 Core XY Printer and have just replaced the Creality Board with a Duet 2 wifi board. Took me ages before I realised that I had to swap the X and Y motors on the board to get it to Home Properly. But when I do issue a G28 I get the following messages:G28 XY
Warning: motor phase A may be disconnected reported by driver(s) 2
Warning: motor phase B may be disconnected reported by driver(s) 2
Also get a message "Response too slow"M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-02-11M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6M2-NW4SD-6JKDL-3SJ6J-19QVK
Used output buffers: 3 of 24 (16 max)
Static ram: 23460
Dynamic ram: 73100 of which 60 recycled
Never used RAM 15460, free system stack 107 words
Tasks: NETWORK(ready,186) HEAT(blocked,294) MAIN(running,449) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:15:41 ago, cause: software
Last software reset details not available
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 33.2, current 34.3, max 34.9
Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 0/471
Driver 1: position 0, standstill, SG min/max 0/528
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-05-26 09:36:04
Cache data hit count 1142496485
Slowest loop: 12.69ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.0ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 31309ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 10, completed moves 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 24.96ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address 8c:ce:4e:d5:b0:aa
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26928
WiFi IP address 192.168.1.31
WiFi signal strength -46dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
My Config.g file is:
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 23 2021 14:06:20 GMT+1000 (Australian Eastern Standard Time); General preferences
M550 P"Ender 6 Experimental" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z100.00 E8000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E720 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X250 Y250 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure active-High endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure active-High endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure active-High endstop for low end on Z via pin zstop; Z-Probe
;M558 P5 C"^zprobe.in" H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
;G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
;M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H0.219 C726.4 D0.46 S1.00 V23.7 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M307 H1 B0 R1.917 C143.1 D6.41 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S260 ; set temperature limit for heater 1 to 260C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossHaver tried increasing max current to 1200ma as the creality stepper motors 42-28 are large steppers. Unable to find any specifications on these motors.
Any clues?
Thanks,
Graham
- WiFi -
@gsolomon said in motor phase A may be disconnected reported by driver(s) 2:
Warning: motor phase B may be disconnected reported by driver(s) 2Well that error is usually pretty accurate. So check your crimps on driver 2.
Driver 2 is driving your Z motor. Does Z movement work correctly?
Also be sure that the jumpers for the ZB connector are in place if you only have one Z motor.
Yup thanks for that info. The jumpers on the seond Z socket were not in place. I was only doing XY so didn't realise that the Z motor was unable to move.
May I suggest especially with Core XY printers, that if a person is unable to get the XY gantry to move in the correct direction using the settings in Config.g, that they swap the X and Y plugs on the board and try again. It worked for me.But thanks for your fantatsic support. Definitely worth paying the extra dollars for a fantastic control board in comparison to that Chinese crap.
Graham
There's a whole section for setting up CoreXY motors
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
