    Weird behavior after M112/M999
    Firmware installation
    • lolorcundefined
      lolorc
      I'm having several issues since I upgraded to 1.19+1.
      most of them are disconnects while uploading gcode files. (WiFi signal strength -61dBm)
      Another issue I just encountered: I just powered the printer on and changed my G31 settings in both config-override and config. I did not accept to reset the duet.
      I was connected to the usb with pronsole and did M112/M999, here are the results after I connect again with pronsole
      [[language]]
      T:23> connect
      No port specified - connecting to /dev/ttyACM1 at 115200bps
      Error: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: rflowokokError: G-CodError: G-Code buffer '$s' length overflowok
      Printer is now online
      Attempt to move the head of a Delta or SCARA printer before homing the towers
      here are the results after I connect with the web ui:
      [[language]]
      12:19:24 PMDisconnected.
      12:19:22 PMError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: Error: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: Error: G-Code buffer '$s' length overflowok
      Error: GCodes: Attempt to read a GCode float array that is too long: Error: G-Code buffer '$s' length overflowokError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: okError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: overflowokError: G-Code bu
      Error: GCodes: Attempt to read a GCode float array that is too long: okError: G-Code buffer '$s' length overflowok
      Error: GCodes: Attempt to read a GCode float array that is too long: overflowokError: G-Code buok
      Error: GCodes: Attempt to read a GCode float array that is too long: Error: G-Code buffer '$s' length overflowError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: okError: G-Code buffer '$s' length overflowokokError: G-Code buffer '$s' length overflowok
      Error: GCodes: Attempt to read a GCode float array that is too long: overflowokError: G-Code buokok
      Error: GCodes: Attempt to read a GCode float array that is too long: rflowError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: okokokokError: G-Code buffer '$s' length overflowError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: overflowokError: G-Code buokokError: G-Code buffer '$s' length overflow
      Error: GCodes: Attempt to read a GCode float array that is too long: rflowError: G-Code buffer '$s' length overflowError: G-Code buffer '$s' length overflow
      another M999 in pronsole and everything is fine, it seems very weird and it's not the 1st time it happens to me.
        Thanks for your report. I will correct the error message in firmware 1.19.1. Looks like the Duet received some junk on one of its GCode input channels.
