[3.3 RC3] All tools heaters appears to be overpowered
@dc42 But the good news is taht the board didn't reset itself at all, i was able to perform 4 times my torture test while i couldn't finish even one before.
So yes i validate the assertion that reset the board fix.M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3RC3+1 (2021-05-29 10:22:51) Bootloader ID: not available Never used RAM 158144, free system stack 4392 words Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,88) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,83) CanClock(notifyWait,0.0%,74) TMC(notifyWait,22.8%,63) MAIN(running,75.7%,303) IDLE(ready,0.0%,40) AIN(delaying,1.4%,263), total 100.0% Last reset 00:30:51 ago, cause: power up Last software reset time unknown, reason: AssertionFailed, available RAM 159320, slot 0 Software reset code 0x0120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20004754 Task HEAT Freestk 142 bad marker Stack: 00000544 0002ebf8 000261ef 42000400 00022423 2002f020 00000000 2002f038 2000151c 00000000 0001d6c1 0002dde4 0002de9c 0002d4a0 00025035 2000159c 00000000 2002f020 00015609 00000000 000009c4 000009c4 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 00025035 Driver 0: position 0, 424.9 steps/mm, standstill, reads 14312, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0 Driver 1: position 0, 917.4 steps/mm, standstill, reads 14311, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0 Driver 2: position 0, 400.0 steps/mm, standstill, reads 14310, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/8, peak Rx sync delay 180, resyncs 0/0, no step interrupt scheduled VIN: 23.8V, V12: 12.2V MCU temperature: min 37.3C, current 37.8C, max 38.4C Ticks since heat task active 229, ADC conversions started 1851316, completed 1851316, timed out 0, errs 0 Last sensors broadcast 0x0000000e found 3 234 ticks ago, loop time 0 CAN messages queued 20737, send timeouts 0, received 15594, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0
@psychotik2k3 thanks. Please post the result of M122 for the main board after you have that "Bad command" message.
@dc42 yes here they are:
06/06/2021, 21:55:19 M122 B0 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3RC3+4 (2021-06-05 16:20:17) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-956BA-NA3TN-6JTD8-3S86J-1UB2T Used output buffers: 3 of 40 (40 max) === RTOS === Static ram: 150896 Dynamic ram: 93488 of which 112 recycled Never used RAM 106840, free system stack 152 words Tasks: NETWORK(ready,28.3%,234) ETHERNET(notifyWait,0.1%,124) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,284) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,340) TMC(notifyWait,7.7%,59) MAIN(running,63.7%,924) IDLE(ready,0.2%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:01:03 ago, cause: power up Last software reset at 2021-06-06 21:54, reason: MemoryProtectionFault mmarValid daccViol, none spinning, available RAM 109912, slot 1 Software reset code 0x4172 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00c00804 BFAR 0xdcfffff5 SP 0x2041fcc8 Task NETW Freestk 569 ok Stack: 2043a6a0 00000001 20418194 00000001 00000000 0047a76f 004239ba 210f0000 a5a5a5a5 0047a88b 00000001 2041fd08 0092dc03 004781bd 204299d0 0041fb41 2041f070 3f1e9901 37533333 43d697a0 00000000 ffffdbb1 fdcbaeaf fffefc23 ffffffff ffffffff ffffffff Error status: 0x04 Aux0 errors 0,4,0 Step timer max interval 129 MCU temperature: min 38.4, current 41.9, max 42.0 Supply voltage: min 23.4, current 23.7, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/40/40, gc cycles 0 Driver 0: position 58520, standstill, reads 24588, writes 18 timeouts 0, SG min/max 0/186 Driver 1: position -12600, standstill, reads 24588, writes 18 timeouts 0, SG min/max 0/191 Driver 2: position 5592, standstill, reads 24588, writes 18 timeouts 0, SG min/max 0/181 Driver 3: position 0, standstill, reads 24588, writes 18 timeouts 0, SG min/max 0/161 Driver 4: position 0, standstill, reads 24596, writes 11 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 24596, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-06-06 21:55:18 Slowest loop: 7.66ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.1ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 9505ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 16, completed moves 16, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 3 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is ready with "M122 B0" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 618, send timeouts 0, received 800, lost 0, longest wait 1ms for reply type 6042, peak Tx sync delay 182, free buffers 49 (min 48), ts 318/317/0 === Network === Slowest loop: 4.19ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0
06/06/2021, 21:55:21 M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3RC3+1 (2021-05-29 10:22:51) Bootloader ID: not available Never used RAM 158144, free system stack 4400 words Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,113) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,83) CanClock(notifyWait,0.0%,74) TMC(notifyWait,22.8%,63) MAIN(running,75.7%,303) IDLE(ready,0.0%,40) AIN(delaying,1.4%,263), total 100.0% Last reset 00:01:05 ago, cause: power up Last software reset time unknown, reason: AssertionFailed, available RAM 159320, slot 0 Software reset code 0x0120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20004754 Task HEAT Freestk 142 bad marker Stack: 00000544 0002ebf8 000261ef 42000400 00022423 2002f020 00000000 2002f038 2000151c 00000000 0001d6c1 0002dde4 0002de9c 0002d4a0 00025035 2000159c 00000000 2002f020 00015609 00000000 000009c4 000009c4 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 00025035 Driver 0: position 0, 424.9 steps/mm, standstill, reads 53827, writes 17 timeouts 0, SG min/max 0/0, steps req 0 done 0 Driver 1: position 0, 917.4 steps/mm, standstill, reads 53829, writes 17 timeouts 0, SG min/max 0/0, steps req 0 done 0 Driver 2: position 0, 406.0 steps/mm, standstill, reads 53833, writes 17 timeouts 0, SG min/max 0/0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/7, peak Rx sync delay 178, resyncs 0/0, no step interrupt scheduled VIN: 23.8V, V12: 12.2V MCU temperature: min 36.2C, current 36.7C, max 36.7C Ticks since heat task active 201, ADC conversions started 66031, completed 66030, timed out 0, errs 0 Last sensors broadcast 0x0000000e found 3 206 ticks ago, loop time 0 CAN messages queued 859, send timeouts 0, received 646, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0
