    DueUI Release v3.3.0 is Now Available
    DueUI
    1
    1
    224
    • gtj0
      gtj0 last edited by
      https://github.com/gtjoseph/DueUI/releases/tag/v3.3.0
      https://github.com/gtjoseph/DueUI/wiki
      Please create new topics for all issues.
      Breaking Changes:
      • This was true for the DueUI 3.2.0 release
        but I'm going to reiterate...You MUST be running a Duet
        board or Duet Software Framework installation at release
        3.1.0 or higher. There were simply too many object model
        differences between DSF and Standalone installations in
        earlier releases and I couldn't keep up with them.
      • If you stored your DueUI
        settings in your dueui_config.json file, the syntax has
        changed slightly. Instead of declaring the settings as a
        class class DueUISettings {, they're now declared as an
        object: configFileSettings = {. See the new default config
        for exact syntax. Other than this change, a configuration
        that worked in the previous version should still work as long
        as it was compatible with RRF 3.1.
      • I'm no longer going to host a DueUI installation at dueui.org.
        It's just too much trouble to maintain.
      Changes:
      • There are no longer separate downloads and default
        configuration files for DSF vs Standalone installations. The
        same zip download and default configuration will work for
        both types of installations.
      • You no longer have to choose between DSF and Standalone
        installation types in Settings. It's autodetected.
      • There is now only one poll interval setting when operating
        in a Standalone installation. With recent changes made to
        RRF, the other poll intervals are no longer needed.
      • A new "Save" button was added to the menubar. It and
        the existing "Save" button in the Settings tab now change
        color when settings are changed to remind you to save them.
        Don't forget, "settings" can include things like jog speeds
        if you configured their widgets to save the value and
        restore it the next time you use DueUI.
      • The underlying JavaScript and CSS files have been
        reorganized to make loading from standalone devices less
        resource intensive. I was noticing that sometimes the pages
        weren't rendering and realized that the Duet had too many
        connections open to service the requests.
      • An "alt" property was added to the image widget to allow
        setting alternate text to be displayed if the image or stream
        can't be loaded.
      Behind The Scenes
      • There was a lot of refactoring done to the connection and
        polling code that should make it more reliable (and easier to
        maintain for me).
