    Conditional setting of G31 based on thermistor input
    Gcode meta commands
    conditional configure g31 offset temperature
    • printernoodleundefined
      printernoodle
      Is there a conditional way to configure (G31 P1000 X0 Y0 Z-0.3) Z offset based on a dedicated thermistor?
      Called in G30 (bed.g) or G29 (mesh.g)?
      RRF 3.3 rc2 DuetWifi2
        dc42 administrators @printernoodle
        @printernoodle check out the G31 C or T parameter (depending on which RRF version you are using).
        printernoodleundefined 1 Reply Last reply Reply Quote 0
          printernoodle @dc42
          SO GOOD
          Thank you!
