Duet with embedded "SBC"
Why duet hasn't taken the route of using processor that has both A-cores + M-cores to get rid of external SBC? Likely you have considered this approach so I'm curious of technical aspects that make this solution worse in comparison to M-cores only + SBC. Thanks
Here are some reasons
- Does anyone make a processor with A-cores, M-cores, and CAN_FD?
- It's most unlikely that we could compete with the cost of a Raspberry Pi + existing Duet. We don't have the advantages of scale that Raspberry Pi does.
- We would have to maintain our own Linux build.
- We would have to provide technical support for all the functions that the SBC provides.
- Some users prefer to use a different SBC, such as Jetson Nano.
- We would need to manufacture separate Duets for those who don't want the SBC functionality.
Thanks for the reply! Some of these are not completely clear to me.
@dc42 said in Duet with embedded "SBC":
Not sure if CAN_FD is present in mentioned combo but I thought there are specialized IC's for CAN_FD?
Not sure how RPi can compete with pricing here since you would not have additional RPi cost but only the cost of Duet? Duet would likely have to be a bit more expensive due to using more expensive processor, though the currently one is definitely not cheap.
I still have old Duet 2 without SBC so my understanding might be a bit off here but aren't you already maintaining your own linux build? Additionally base yocto and/or buildroot images are often provided by manufacturers.
That's a tough one although considering how much issues you had with SBC communication maybe it would not be so bad. Just a thought.
Definitely a downside although linux to linux communication is not so hard so people could easily add more computers if they wish to do so.
Maybe its misunderstanding here but I would not think that separate duet boards are necessary because duet would in that case effectively be SBC and maybe a stripped down version of linux could be made for those who absolutely would not want any applications.
