    can't enable endstops in corexy
    Using Duet Controllers
    • TristanKoeln
      TristanKoeln last edited by
      hey, i cant enable my endstops with my sensorless homing on corexy, im using the duet wifi.
      config:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 20:25:38 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"CosplayPrinter"                             ; set printer name
      M669 K1                                            ; switch to CoreXY mode
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M569 P4 S1                                         ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4                                 ; set drive mapping
      M350 X128 Y128 Z128 I0                             ; configure microstepping without interpolation
      M350 E16:16 I1                                     ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00:420.00           ; set steps per mm
      M566 X1800.00 Y1800.00 Z120.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
      M203 X18000000 Y18000000 Z120.00 E1200.00:1200.00  ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00         ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z400 E800:800 I30                ; set motor currents (mA) and motor idle factor in per cent
      M208 X0 Y0 Z-10 S1                                 ; set axis minima
      M208 X400 Y400 Z200 S0                             ; set axis maxima
      ; StallDetaction
      M915 X Y R0 F0                                     ;X Y stalling no action
      M574 X S4
      M574 Y S4                                        ; configure sensorless endstop for low end on X and Y                                        ; configure sensorless endstop for low end on Y
      M574 Z1 S1 P"zstop"                                ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H10 F120 T30000                            ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"pt1000" R4700                  ; configure sensor 1 as PT1000 on pin e0temp
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1                                     ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"WaterColledHead" D0 H1 F-1               ; define tool 0
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      Homeall:
      ; homeall.g
      ; called to home all axes
      M913 X70 Y70           ; return current to 70%
      G91                      ; relative mode
      G1 H1 X-240 Y-240 F10000 ; coarse home X or Y
      G1 H1 X-240              ; coarse home X
      G1 H1 Y-240              ; coarse home Y
      G1 X4 Y4 F600            ; move away from the endstops
      G1 H1 X-10               ; fine home X
      G1 H1 Y-10               ; fine home Y
      G1 H1 Z-215 F360         ; move Z down stopping at the endstop
      G90                      ; absolute positioning
      G92 Z-10                 ; set Z position to axis minimum (you may want to adjust this)
      M913 X100 Y100           ; return current to 100%
      ;G91                    ; relative positioning
      ;G1 Z10 F500            ; lift Z relative to current position
      ;G90                    ; absolute positioning
      HomeX or Y:
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 20:25:39 GMT+0200 (Mitteleuropäische Sommerzeit)
      M913 X70 Y70       ; drop motor current to 70%
      G1 H2 Z10 F30000   ; lift Z relative to current position
      G1 H1 X-405 F10000 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F10000    ; go back a few mm
      G1 H1 X-405 F360   ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-10 F30000  ; lower Z again
      M400
      M913 X100 Y100     ; retrun current to 100%
        Phaedrux Moderator @TristanKoeln last edited by
        @tristankoeln said in can't enable endstops in corexy:
        M574 X S4 M574 Y S4
        I think you want S3, not S4
