    Setup temp01 sensor on Toolboard for ambient
    Using Duet Controllers
    • kingofthegeeksundefined
      kingofthegeeks
      If I wanted to attach a standard thermistor to temp01 on the toolboard and just monitor the ambient temperature within the printhead enclosure or on the stepper motor, is this possible ?
      I've managed to get an IDEX up and running just by following the guides and reading the forum, I'm almost embarrassed this seemingly simple task eludes me ...
      feeshfeudundefined 1 Reply Last reply Reply Quote 0
      • feeshfeudundefined
        feeshfeud @kingofthegeeks
        It's possible. I can't say that this is the most correct way of doing it but I've just configured my misc. temp sensors to unused heaters:
        e.g.
        M308 S1 P"temp1" Y"thermistor" T100000 B4138 A"radiator" ; configure thermistor for measuring radiator temp
        M950 H1 C"out8" T1 Q0 ; configure heater for 'extruder' (NOT USED)
        Here I'm not using H1 or 'out8' for anything. Of course configure to your thermistor and input ('temp1' for me).
          dc42 administrators @feeshfeud
          @feeshfeud said in Setup temp01 sensor on Toolboard for ambient:
          e.g.
          The M950 line isn't necessary if you just want to monitor the temperature. In Duet Web Control, if you click on the Extras link in the tools pane then you will be able to display the extra temperature in the chart.
            kingofthegeeks
            Thank you both, like I expected, embarrassingly simple.
