Solved [?] Stepperonline Stepper Motor
I have the Stepperonline Stepper motor and here are some quick specs;
3D printer motor with high torque
59Ncm(83.6oz.in) holding torque
NEMA 17 bipolar 1.65"x1.65"x1.89" 4-wire
Build with 39.37"( 1m) Cable and 0.1" pitch Connector
Rated current 2.0A & resistance 1.4ohmsMy question is about the amperage. 2.0A is equivalent to 2000mA right? Is that what I put down under the motor current of the configurator? I ask this because when I did it said it's going to need a cooling part warning. So I put 1999 and it took that fine.
Any help would be appreciated.
@gyrene2083 stepper motors get hot at full rated current. In 3D printers, it's more normal to run them at 75% to 85% of rated current.
@dc42 Thank you so much for clearing that up for me. I just want to ensure I have all the information needed to fill out the configurator correctly. Thank you.
