    Autostart of plugins?
    Plugins for DWC and DSF
    602
    • resamundefined
      resam
      I've written two plugins for my printer and installed them successfully.
      But every time I power off my printer and SBC, the plugins need to be manually started via DWC -> Settings -> Machine-specific plugins.
      Is there a way to make them autostart? from the DSF wiki it sounded like it should... but it doesn't.
      Here is one of my plugin.json files:
          "id": "FilamentLoadCell",
          "name": "Filament-Load-Cell",
          "author": "Thomas Kriechbaumer",
          "version": "1.0.0",
          "license": "MIT",
          "homepage": "https://github.com/Kriechi",
          "sbcRequired": true,
          "sbcDsfVersion": "3.3",
          "sbcExecutable": "filament_load_cell.py",
          "sbcExecutableArguments": null,
          "sbcOutputRedirected":  true,
          "sbcPermissions": ["registerHttpEndpoints"]
      • chrishammundefined
        chrishamm administrators
        @resam DSF saves the plugin execution state only when DCS shuts down and/or installs updates. So by pressing E-STOP you should be able to save the execution state for the next reboot. I'll improve that in the next version.
        Duet software engineer
        resamundefined 1 Reply Last reply Reply Quote 0
        • resamundefined
          resam @chrishamm
          @chrishamm I enabled my plugins, waited for their startup message notification, then pressed "Emergency Stop" in DWC, and they plugins were auto-started.
          However, after a proper SBC shutdown + power cycle, they again did not start automatically.
          Where should the execution state be saved to on the SBC?
            chrishamm administrators @resam
            @resam The plugins that are supposed to be auto-started are stored in /opt/dsf/conf/plugins.txt. It's a simple text file where each line is a plugin ID.
            • resamundefined
              resam @chrishamm
              @chrishamm said in Autostart of plugins?:
              yep - after pressing E-Stop the file gets correctly written with my plugin IDs.
              I verified that the files looks good - and rebooted the SBC.
              ... and the file is empty after I logged into the SBC again.
              I manually stopped all DSF systemd services one by one, and the plugins.txt file was still good. I rebooted - and it worked! And then did a simple full reboot (without manually stopping the services one by one), and it didn't work again.
              Feels like DCS is truncating/resetting the file during shut down of one of the processes - some kind of race condition between duetcontrolserver and duetpluginservice?
              I also realized that I had duetpluginservice and duetpluginservice-root enabled and running at the same time... probably not recommended? However, if I disable the -root.service, then E-Stop does not persist my plugins.txt any more...
                @resam I may have found something in DSF which I'll address in the next version. I believe the plugin services could receive a shutdown request before DCS which would cause the plugin states to be reset before that file is correctly written.
                Both services are required for plugins; the regular duetpluginservice executes normal (non-root) plugins and and the duetpluginservice-root executes elevated plugins (like DuetPi Management Plugin) and it maintains AppArmor profiles for each plugin. So they're both needed.
                • resamundefined
                  resam @chrishamm
                  @chrishamm thanks! I'll keep both services enabled then.
                  For now I simply hacked in a cronjob to curl the endpoint to start my plugins. If anyone else needs this hotfix, it goes something like this:
                  $ crontab -e
                  <an editor opens: at the bottom insert this line for each of your plugin>
                  /usr/bin/bash "sleep 30 && curl 'http://localhost/machine/startPlugin' --data-raw 'MyPluginID'"
                  Save, and exit, and reboot -- and you plugins should start after 30 seconds or so.
                  chrishammundefined 1 Reply Last reply Reply Quote 1
                    @resam Interestingly enough my plugins seem to restart properly if I reboot the Pi with M999 B-1 (requires DuetPiManagementPlugin). But anyway, I'll improve the underlying code in the next version.
                    • resamundefined
                      resam @chrishamm
                      @chrishamm At this point I probably should admit that I am not using the DuetPi image - but installed everything from the Duet apt repos into my existing Pi... but the systemd service files are the same - so their Before/After dependencies should be correct as you wrote them.
