[3.3 release] object model heater active temp stays at 0
hi,
i noticed this on the release version of RRF3.3
i have a macro that i luanch at the start of the print.
It will check all my tools and if one tool got it's heater's active temp superior to 180 then i perform a purge a wipe and a prime line
this way i'm sure all my tools are ready for the print and if there's any problem i'm aware of it at the beginning.today twice i had the problem that one of my tools (not the same) didn't perform the purge wipe prime, and thanks to the traces i put i noticed that the active temp was at 0.
i checked and yes it stayed at zero even if i change the temps through the panel due or the DWC
all my heaters are plugged on my H3C expansion board while the MB6HC got the XYZ motors, part cooling fan, bed heater and z probe
@psychotik2k3 I can't reproduce this. Are you running in standalone mode or SBC mode?
@dc42 stand alone
