Backup config DWC 3?
Hi all,
Been away for a while but a new project has popped up and I am back printing again.
looks like things have moved on here so I have updated to DWC 3.3.0 and worked through making a new configuration and before I load it up I wanted to backup the existing.......
I used to be able to select all and export as a .zip but now the only option is delete.
is there a way I am missing or do I need to pull the SD and make a manual backup?
Thanks in advance
@opentoideas You must not select subdirectories because recursive file operations are not supported yet. If you select only the files in /sys, you should be able to pull them down as a ZIP file.
@chrishamm - lol simple when you know how!
Thank you so much - I couldn't believe it wasn't available in the new version so figured I
was missing something
