    Wifi connection issues
    Firmware installation
    • Mikezim69undefined
      Mikezim69
      Hi,I'm trying to turn on the wifi module on my duetwifi with M552 S0 but keep getting Error:Failed to initialise WiFi module,code -10.Is this a problem with my board or is it a firmware issue? Thanks in advance
        That usually means that your main firmware and wifi firmware are incompatible. For example, you may have upgraded the main firmware to 1.19 but not the wifi firmware. If that's what you have done, copy the new DuetWiFiServer.bin file into /sys on your SD card (renaming it to remove any version numbers from the filename after you copy it), and send M997 S1 to install it.
