    3.4b1 SBC mode M702 crashes DCS
    Beta Firmware
    • Serbitarundefined
      Serbitar
      Hi!
      With 3.4b1 installed on my MB6HC + raspi changing fillament appears to be imposible. Indeed M702 causes DCS to crash and has to be manually restarted.
      	m122
      RepRapFirmware for Duet 3 MB6HC version 3.4.0beta1 (2021-07-10 16:20:28) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9D8-3S86J-9B36F
      Used output buffers: 1 of 40 (10 max)
      Static ram: 150904
      Dynamic ram: 64380 of which 36 recycled
      Never used RAM 138872, free system stack 219 words
      Tasks: ACCEL(notifyWait,0.0%,348) SBC(resourceWait:,0.3%,308) HEAT(delaying,0.1%,325) Move(notifyWait,0.0%,300) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,6.6%,93) MAIN(running,92.7%,967) IDLE(ready,0.3%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:03:02 ago, cause: software
      Last software reset at 2021-07-13 16:56, reason: User, GCodes spinning, available RAM 135800, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 740
      MCU temperature: min 45.6, current 45.8, max 46.9
      Supply voltage: min 0.2, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 0.1, current 12.2, max 12.8, under voltage events: 0
      Driver 0: position 0, standstill, reads 36701, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 36701, writes 11 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 36701, writes 11 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 36701, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 36702, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 36702, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-07-13 16:59:57
      Slowest loop: 26.60ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 1625, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 913/0/0
      Tx timeouts 0,0,912,0,0,711 last cancelled message type 4514 dest 127
      === SBC interface ===
      State: 4, failed transfers: 0, checksum errors: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 793/793
      SPI underruns 0, overruns 0
      Disconnects: 1, timeouts: 1, IAP RAM available 0x2c7a4
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.4-b1
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 37.82, max wait times: 56.8ms/0.0ms
      Codes per second: 0.05
      Maximum length of RX/TX data transfers: 3096/40
      Systemd log
      log.txt
      • chrishammundefined
        chrishamm administrators @Serbitar
        @serbitar Thanks for the report, I am looking into it.
        Duet software engineer
          This will be fixed in the next version.
