Using variables with M584 doesn't work
@carlosr No, it does not.
When is the use of arrays expected to be implemented in SBC mode? In 3.4 version?
This is what we need to be able to fully operate our machine with the dynamic selection printheads.Why are there such differences in functionality between standalone and SBC with the same version?
@CarlosR tried to make it work with other methods but a lot of functionality is lost. (By the way, he's in our developing team).
Would the use of array variables work in version 3.3 in standalone mode, or would it not work either?
@marcossf The upcoming version v3.4-b2 will support array expressions in the form
M584 E{123,456,global.paramXYZ}
both in standalone and SBC mode. The reason this already worked in standalone is because RRF parses text-based G-codes whereas DSF in SBC mode reads them and then wraps them into binary format for performance reasons. -
@chrishamm Thank you very much. We'll wait anxiously for version 3.4 b2
@marcossf to be clear, in 3.3 standalone mode (but not SBC mode) you can do things like this:
M92 E{var1}:92:{var2}
i.e. any individual value can be replaced by an expression. In 3.4beta2 that will no longer be allowed, but in both standalone and SBC mode you will be able to use this:
M92 E{var1,92,var2}
@dc42 Last question about this topic from my side:
I think the critical command would be M584 since we are writing our drives as 20.0, 21.0, 22.0.
How would this be stored as variables?
We are thinking on storing only the integer value, and add the .0 board to each of them:M584 E{{var1}.0, {var2}.0, {var3}.0}
@carlosr said in Using variables with M584 doesn't work:
I think this would work:
M584 E{var1+0.0, var2+0.0, var3+0.0}
The +0.0 converts the value from integer to float, and in 3.4 we allow a float that is close to an exact multiple of 0.1 to be converted to a driver ID.
@dc42 It sounds great. Thank you!
@dc42 We need SBC mode as premise, so as you said to @CarlosR if the variable format its right for us, we will wait for 3.4 version.
We will have a lot of printheads, which need to identify by their CAN ID and the position in their dock, to assign their specific variables (GPIOs, offsets, fans, thermal, leds, etc). Doing it without this variable array would be imposible.
I hope could been released soon.
@dc42 Hi, we are testing this with 3.4.0beta2 version, but doesn't work.
We tried:M584 E{var.driverZero+0.0,var.driverOne+0.0,var.driverTwo+0.0}; extruders drive mapping
Where var.driverZero, ..., are integer values (20,21,22)
And we also tried to store the float value itself in an aux variable manually to test if the command recognise the params:
var driverZeroF = 20.0 var driverOneF = 21.0 var driverTwoF = 22.0 E{var.driverZeroF,var.driverOneF,var.driverTwoF}; extruders drive mapping
None of them worked...
@carlosr have you verified using M115 that you really are running firmware 3.4beta2?
@dc42 @CarlosR I've checked the version for you. Hope it can be solved.
9/8/2021 10:15:09 m115 b22 Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09) 9/8/2021 10:15:06 m115 b21 Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09) 9/8/2021 10:15:04 m115 b20 Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09) 9/8/2021 10:15:01 m115 b45 Duet EXP1XD firmware version 3.4.0beta2 (2021-08-03 10:00:36) 9/8/2021 10:14:59 m115 b44 Duet EXP1XD firmware version 3.4.0beta2 (2021-08-03 10:00:36) 9/8/2021 10:14:58 m115 b43 Duet EXP1XD firmware version 3.4.0beta2 (2021-08-03 10:00:36) 9/8/2021 10:14:55 m115 b42 Duet EXP1XD firmware version 3.4.0beta2 (2021-08-03 10:00:36) 9/8/2021 10:14:53 m115 b41 Duet EXP1XD firmware version 3.4.0beta2 (2021-08-03 10:00:36) 9/8/2021 10:14:49 m115 b40 Duet EXP1XD firmware version 3.4.0beta2 (2021-08-03 10:00:36) 9/8/2021 10:14:39 m115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-08-03 12:42:44
By the way, it's SBC mode.
@carlosr we have confirmed that this is a problem. It will be fixed in the next 3.4beta release.
@dc42 said in Using variables with M584 doesn't work:
Do you have an estimated date when version 3.4 will be released? We had to stop the project due to the problem of the use of variables with 3.4.0b2 and SBC.
@marcossf said in Using variables with M584 doesn't work:
I can provide you with a preview build if you like. Which Duet are you using?
@dc42 We are using Duets 6HC, 1LC and 1XD boards, as shown in the versions above, in SBC mode.
If you can anticipate the new beta release, @CarlosR can continue developing the configuration for this machine. So, we will also see other possible problems that we will undoubtedly find after that step.
Obviously it will be delivered to the client when it is at least a stable version, hopefully 3.4 soon.
Thanks!
@marcossf you can find an unofficial 3,4beta2+ build for the Duet 3 main board at https://www.dropbox.com/sh/cq7q3g8coymo9s3/AABtPYEzV1_unETpKEMPInSia?dl=0. The 3.3 firmware for the 1LC and 1XD boards will work with it.
@dc42 OK, huge thanks. We will test it asap.
It's necesary to back the 1XD and 1LC boards to version 3.3 or would be valid leave it in 3.4b2?
For the 6HC, upload the bin and map files to /sys from DWC it's enough?
@marcossf if the 3.4beta files are working for you on the 1LC and 1XD boards, you can continue using them. However, a small number of users have reported issues with inaccurate temperature readings on the 1LC using 3.4beta firmware, which I have been unable to reproduce. If you experience this, then I suggest you downgrade the tool board firmware to 3.3.
