    X-axis not responding to x-axis limit SW
    Using Duet Controllers
    • Handymanpa54undefined
      Handymanpa54
      New setup with Duet2 Ethernet. X-axis not responding to x-axis limit SW. Limit sw are nc and I see they do work and turn on the light for it's axis. I also noticed the motors move so slow.
      I want to calibrate movement. I think that has to do with steps per mm. I just need to move what should be 100mm. Until homed I can't get it to move.
      Poibt me in the right direction.
      Mark
      code_text
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 30 2021 11:14:49 GMT-0400 (Eastern Daylight Time)
      M550 P"CNC 6040"                                   ; set printer name
      M552 P192.168.1.14 S1                              ; enable network and set IP address
      M553 P255.255.255.0                                ; set netmask
      M554 P192.168.1.2                                  ; set gateway
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X400.00 Y400.00 Z400.00 E420.00                ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 E500 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M208 X390 Y590 Z68 S0                              ; set axis maxima
      M574 X1 S1 P"^xstop"                               ; configure active-high endstop for low end on X via pin ^xstop
      M574 Y1 S1 P"^ystop"                               ; configure active-high endstop for low end on Y via pin ^ystop
      M574 Z1 S1 P"^zstop"                               ; configure active-high endstop for low end on Z via pin ^zstop
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"CNC6040" D0 H1 F0                        ; define tool 0
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
        dc42 administrators @Handymanpa54
        @handymanpa54 to move an individual motor before axes have been homed, send G91 to select relative movement, then use G1 H2 moves. For example, G1 H2 X10 should move the Z motor 10mm forwards.
