    Setting Zero Using G54, G55, …
    CNC
    gcode
    2.2k
    • raylee14undefined
      raylee14
      I’m using a cnc GRBL machine and Universal Gcode Sender.
      I’m trying to save a default position to G54
      I first place the spindle to a corner.
      Then I run this to set the zero position:
      G10 L20 P1 X0 Y0 Z0
      Next, I move the spindle to a certain position and run this to return to the zero I set:
      G54 X0 Y0 Z0
      It works as my expectation.
      However, when I press the Reset Zero button on the Universal Gcode Sender, the machine zero I set is reset.
      Not sure if I have any misunderstanding to this.
      Thanks in advance
      EducatingSavvasundefined 1 Reply Last reply Reply Quote 0
      • EducatingSavvasundefined
        EducatingSavvas @raylee14
        @raylee14 said in Setting Zero Using G54, G55, …:
        10 L20 P1 X0 Y0 Z0
        G54 X0 Y0 Z0
        GRBL has different gcode command enabled compared to Reprap. This library has a table of the code and supported platforms which it's enabled on: https://reprap.org/wiki/G-code#G92:_Set_Position
        It's been a long while since I've used grbl but I think you might want to use G92?
        raylee14undefined 1 Reply Last reply Reply Quote 0
        • raylee14undefined
          raylee14 @EducatingSavvas
          @educatingsavvas
          Does it mean I should use G92 X0 Y0 Z0 to set zero instead of using 'Reset Zero' button on Universal Gcode Sender? How can I specific where to save the position in G54-G59?
          I find that the button is running G10 P0 L20 X0 Y0 Z0
          and the Return to Zero button is G90 G0 X0 Y0; G90 G0 Z0
          Sorry for the newbie question
          dc42undefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @raylee14
            [deleted]
              That is an invalid command. The P value for that G10 command must be a coordinate system number in the range 1 to 9. See section 3.5.5 of the NIST GCode standard.
                dc42 administrators @dc42
                PS - I've just discovered that LinuxCNC supports an extended version of G10 in which P0 is allowed and means use the current coordinate system. That's not currently supported by RRF, but I can add it in the next 3.4 beta release.
