    RRF3.3 meta functions don't work when in cnc mode
    Gcode meta commands
    • Clausundefined
      Claus
      I am new here and maybe I am wrong, but may be there is a bug related to the meta functions.
      I use RepRapFirmware 3.3 stable with a new Duet 3 Mainboard 6HC in standalone mode.
      As you can see in the picture meta functions are not reconized when in cnc mode M453 and are reconized if in mode FFF M 451.
      Test.g used is simply this
      the same thing happens in the config.g or in macros.
      I have searched the forum but have not found any reference to this.
        dc42 administrators @Claus
        @claus from https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands:
        Sub-expressions may be enclosed in { } or in ( ). The outermost level must always be { } because standard CNC GCode uses ( ) to enclose comments. RepRapFirmware treats ( ) as enclosing subexpressions if they appear inside { }, and as enclosing comments when they do not.
        This also applies to round brackets used to surround function argument lists. So you need to use:
        if {!exists(global.XMax_default)}
        and
        var a = {abs(10)}
        • Clausundefined
          Claus
          @dc42 I had read that part but didn't realize it also referred to round brackets used to surround function argument lists.
          Thank you it works perfectly.
            @claus I'm glad it's working for you now. I have just updated that part of the documentation.
            • Clausundefined
              Claus
              I really appreciated the care You put in the continuous updating of the Duet and it is one of the reasons why I chose your product.
