    2nd laser head on 1 axis
    Laser Cutters
    1
    1
    135
    • g0rgundefined
      g0rg
      I actually use this is my config.g for my laser diode to work and it works well :
      M452 C"exp.heater3" F100 ; laser uses heater3 pin,  PWM frequency 100Hz
      My questions are
      • How to setup a second laser head in the same axis ?
      • Do i need to setup tools for that purpose ?
      • Can i set M452 2 times
      The purpose is to send the same ttl signal through 2 outputs in order to "clone" an engraving job on 2 lasers in the same time
      No need of an idex system, it's just a second laser head aside the 1st one
      Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
