    3.4b3 speed variations
    Beta Firmware
    • Sergeundefined
      Serge
      Hello, I have a printing problem on SBC + Duet3. Indeed, during printing the requested speed is 80mm / s during long straight lines and the head only reaches 62mm / s maximum with a cyclic speed variation. on arrival of the changes of direction, the head slows down considerably in the order of 5 mm / s with a very strong under extrusion. I performed the 3.4b3 update yesterday. Do you have a clue? Thanks in advance.
      config.g
      • chrishammundefined
        chrishamm administrators
        @serge It's most likely caused by PA + your low extruder jerk (instantaneous speed change). Once you increase it, you'll find that the print speed increases, too. See here for further details.
        Duet software engineer
          Try these values for E
          M566 E3000
          M203 E6000
          M201 E3000
          That should allow pressure advance to work properly
