[3.4b3] Homing coupler does not work correctly
@diamondback thanks, I'll mark this thread as solved.
@dc42 I've been running the firmware build you posted here ever since you did, and no more issues with the coupler! Definitely seems solved!
@dc42 I have good news and bad news
I just upgraded my entire TC from Duet 2 to Duet 3 hardware and also to 3.5b1.
The good news is that this issue did not happen anymore at all with the duet 2 hardware (on 3.4.5), however, now with Duet 3 on 3.5b1, it happens againI haven't tested Duet 3 on 3.4.5, so not sure if it's Duet 3 specific or 3.5b1...
Any ideas what could have caused this regression?
undefined Diamondback has marked this topic as unsolved
@Diamondback please check whether the symptom is exactly the same as you describes at the start of this thread, and start a new thread with any appropriate amendments. Post the config.g and relevant homing files for your new configuration.
@dc42 Hm, this is very odd timing.... It turns out, the grub screw of my coupler was loose and that's what made it look like it wasn't homing correctly... Weird that this happens right after a firmware upgrade
Not 100% sure this was the only issue, but I will assume so for now, sorry for the confusion.
undefined Diamondback has marked this topic as solved
@Diamondback thanks for the update! Over the years I have seen many instances of faults being blamed on a software update, when in reality something else just happened to go wrong at the same time.
@dc42 Yea same... I hate bad timing...
@dc42 As it turns out, this was not "just" a loose coupler and bad timing. I kept getting this issue even after fixing the coupler shaft grub screw.
It appears that the switch from Duet 2 Wifi to Duet 3 6HC for the coupler stepper had an impact on its torque. With the same settings in config.g it now stalled from time to time during homing before it reached its hard endstop (where it's supposed to stall).
I think I fixed it by increasing the current a little, at least I haven't seen the issue again afterwards.
Is a change of output torque expected when changing the stepper driver even if it's using the same settings?
@Diamondback said in [3.4b3] Homing coupler does not work correctly:
That's entirely possible, because the current can't be set to exactly the value you requested, as only certain values are available. RRF gives you the closest available lower current unless the next higher available current is only slightly higher. The TMC2160 or 5160 drivers provide finer current control than the TMC2209 at low currents.
@dc42 Ah ok, that makes sense then, thank you
