    Upgrading from duet 0.8.6
    Firmware installation
    • Dave Parry
      Dave Parry last edited by
      As my old duet has expired, I have a duet 2 ethernet coming tomorrow. Can I use the config files from my old setup or do I have to make new ones?
        I'm not very familiar with the old boards, but I would say that since you're starting with a new board that likely has RRF3 on it, you're going to need to update the config anyway.
        I suggest using the config tool to generate a new file set for RRF3. You can use the values from your existing config as a road map.
        https://configtool.reprapfirmware.org/Start
