DWC 3.4.0-b3 m122 command not producing output.
I have Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta3 (2021-08-24)
Duet WiFi Server Version: 1.26M122 diagnostics has no outputnot sure if this is a dwc issue or a firmware issue. Any help would be appreciated
Did you update DWC along with the firmware?
Where are you sending M122 command? Do you have multiple DWC windows/connections open from multiple devices? Do you also have a paneldue?
