    Version 3.3 compilation issues
    Firmware developers
    86
    • jazbaatbadalgaye
      jazbaatbadalgaye last edited by
      I am getting the following error while compiling 3.3-dev version
      make -j8 all
      c:/program files/gnu arm eclipse/build tools/2.6-201507152002/bin/sh: C:/Program: not found
      makefile:96: recipe for target 'all' failed
      make: *** [all] Error 127
      I have made sure that all relevant files are in the path but I still get the error.
        dc42 administrators @jazbaatbadalgaye last edited by
        @jazbaatbadalgaye you needs to put quotation marks around that file path, because it contains spaces.
        jazbaatbadalgaye 1 Reply Last reply Reply Quote 0
        • jazbaatbadalgaye
          jazbaatbadalgaye @dc42 last edited by
          I did but it still gives me the same error
            @jazbaatbadalgaye which project are you trying to build? If you are trying to build the DuetWiFiSocketServer project, don't bother. You don't need to build that project to build RepRapFirmware.
            • jazbaatbadalgaye
              @dc42 I am trying to build the RepRapFirmware
                @jazbaatbadalgaye which version of Eclipse are you using, as reported by Help > About Eclipse IDE ?
                • jazbaatbadalgaye
                  @dc42 I am using version: 2021-06 (4.20.0)
                    @jazbaatbadalgaye that's the same version that I use.
                    Please go to the command prompt and run these commands:
                    where make
                    where sh
                    The response to the first one should be:
                    C:\Program Files\GNU ARM Eclipse\Build Tools\2.6-201507152002\bin\make.exe
                    and similarly for the second.
                    jazbaatbadalgaye 2 Replies Last reply Reply Quote 0
                    • jazbaatbadalgaye
                      @dc42 said in Version 3.3 compilation issues:
                      I am getting the same thing among other installations of make.exe. Similarly for sh
                      • jazbaatbadalgaye
                        jazbaatbadalgaye @jazbaatbadalgaye last edited by
                        @jazbaatbadalgaye @dc42 I was able to compile after a fresh install of eclipse
                        • jazbaatbadalgaye
                          jazbaatbadalgaye @dc42 last edited by jazbaatbadalgaye
                          @dc42 Now I have new issues for some reason
                          C:\Users\AS\Documents\GitHub\RepRapFirmware 3.3\RepRapFirmware\src\Hardware\SAM4E/Devices.h:13:10: fatal error: USARTClass.h: No such file or directory
                             13 | #include <USARTClass.h>
                          compilation terminated.
                          In file included from C:\Users\AS\Documents\GitHub\RepRapFirmware 3.3\RepRapFirmware\src/RepRapFirmware.h:66,
                                           from C:\Users\AS\Documents\GitHub\RepRapFirmware 3.3\RepRapFirmware\src/GCodes/GCodeException.h:11,
                                           from ../src/bossa/Samba.h:37,
                                           from ../src/bossa/Applet.h:34,
                                           from ../src/bossa/Applet.cpp:29:
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/Device.o' failed
                          make: *** [src/bossa/Device.o] Error 1
                          make: *** Waiting for unfinished jobs....
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/Applet.o' failed
                          make: *** [src/bossa/Applet.o] Error 1
                                           from ../src/bossa/Device.h:32,
                                           from ../src/bossa/Flasher.h:32,
                                           from ../src/bossa/Flasher.cpp:30:
                          C:\Users\AS\\GitHub\RepRapFirmware 3.3\RepRapFirmware\src\Hardware\SAM4E/Devices.h:13:10: fatal error: USARTClass.h: No such file or directory
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/Flasher.o' failed
                          make: *** [src/bossa/Flasher.o] Error 1
                                           from ../src/bossa/WordCopyApplet.h:32,
                                           from ../src/bossa/WordCopyApplet.cpp:29:
                                           from ../src/bossa/Samba.cpp:29:
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/Samba.o' failed
                          make: *** [src/bossa/Samba.o] Error 1
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/WordCopyApplet.o' failed
                          make: *** [src/bossa/WordCopyApplet.o] Error 1
                          make: *** [src/bossa/WordCopyArm.o] Error 1
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/EefcFlash.o' failed
                          make: *** [src/bossa/EefcFlash.o] Error 1
                          src/bossa/subdir.mk:42: recipe for target 'src/bossa/BossaFlash.o' failed
                          make: *** [src/bossa/BossaFlash.o] Error 1
                          I am able to build version 3.4 without any issues though
                          Here is how my directory looks
                          I have just added both coren2g and coreng for sanity check
                          dc42 jazbaatbadalgaye 2 Replies Last reply Reply Quote 0
                            @jazbaatbadalgaye to build 3.3 you need the corresponding 3.3 version of CoreN2G and maybe also RRFLibraries.
                            • jazbaatbadalgaye
                              @jazbaatbadalgaye It compiled after I included a tagged release (16th June?) I included the exact versions the wiki said but weirdly it did not compile then. I used the 3.3 dev version as listed in the wiki. Hopefully the wiki will be updated. Cheers!
