    Cyrillic file names on 12864mini
    Using Duet Controllers
    • Vladimir_Uundefined
      Vladimir_U
      Hello everyone.
      Connected 12864mini display to duet3mini 5+.
      Installed https://github.com/jadonmmiller/UltimateDuetMenuSystem
      The problem is that the Cyrillic names of the gcode files are displayed incorrectly. (Photo)
      I also noticed that you can set negative temperatures (photo)
      UltimateMenuSystem developer claims these are firmware limitations.
      Is there a way to fix this?
      I would also like to translate the entire 12864 menu into Russian.
      Will there be such an opportunity?
        dc42 administrators @Vladimir_U
        @vladimir_u I've added Cyrillic support on the 12864 to the work list.
