    M600 Doesn't seem to work with SBC
    Beta Firmware
    • janusofdoors
      janusofdoors last edited by
      I saw the 3.4.0b3 fixed the bug with Duet 3 with SBCs not working with M600. I upgraded to 3.4.0b4 and gave this a try tonight but can't seem to get this to work. The printer does run filament-change.g and then runs resume.g, but then decides to restart the print. Looking at the resurrect.g file shows the printer restarting the print(M23). I have included the relative files below.
      ; File "0:/gcodes/top_dedication.gcode" resume print after print paused at 2021-10-06 01:21
      G21
      M140 P0 S65.0
      G29 S1
      T-1 P0
      G92 X218.939 Y289.344 Z0.200
      G60 S1
      G10 P0 S195 R210
      T-1 P0
      M98 P"resurrect-prologue.g"
      M116
      M290 X0.000 Y0.000 Z0.000 R0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      G54
      M106 S0.00
      M106 P0 S0.00
      M116
      G92 E0.00000
      M83
      M486 S-1
      G17
      M23 "0:/gcodes/top_dedication.gcode"
      M26 S5589
      G0 F6000 Z2.200
      G0 F6000 X218.939 Y289.344
      G0 F6000 Z0.200
      G1 F1080.0 P0
      G21
      M24
      ; filament-change.g
      M83                  				; relative extruder moves
      G1 E-2 F1200        				; retract 2mm of filament
      G91									; relative positioning
      G1 Z2 F600							; lift Z by 2mm
      G90									; absolute positioning
      G1 X10 Y10 F10000					; go to X=0 Y=0
      M291 P"Swap filament" S2
      G1 E10 F1200        					 ; extrude 10mm of filament
      G1 H0 E10 F300 						; extruding filament
      M291 P"Clean Nozzle" S2 T30
      ; resume.g
      ; called before a print from SD card is resumed
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 29 2020 01:54:12 GMT-0400 (Eastern Daylight Time)
      ;M220 S60							;slow the print down on first new layer
      G90			;relative moves
      G1 R1 X0 Y0 Z2 F6000 ; go to 2mm above position of the last print move
      G1 R1 X0 Y0 Z0 F500        ; go back to the last print move
      G1 E1 F1200         ; extrude 1mm of filament
      This is the console, I ran M122 before I hit resume. After returning to the last position the printer seems to go into resurrect.g and restarts the file.
      10/6/2021, 1:18:10 AM M24
      Printing resumed
      10/6/2021, 1:17:10 AM m122
      RepRapFirmware for Duet 3 MB6HC version 3.4.0beta4 (2021-09-27 11:31:18) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6J9D6-3SJ6M-KA6AG
      Used output buffers: 1 of 40 (24 max)
      Static ram: 151080
      Dynamic ram: 63236 of which 24 recycled
      Never used RAM 135612, free system stack 138 words
      Tasks: SBC(resourceWait:,0.6%,322) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.6%,246) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,366) CanClock(delaying,0.0%,339) TMC(notifyWait,9.0%,58) MAIN(running,89.7%,921) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 02:00:04 ago, cause: software
      Last software reset at 2021-10-05 23:17, reason: User, GCodes spinning, available RAM 136116, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 154
      MCU temperature: min 47.2, current 47.5, max 47.6
      Supply voltage: min 23.8, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
      Driver 0: pos 3200, standstill, SG min/max 0/147, reads 52949, writes 0 timeouts 0
      Driver 1: pos 0, standstill, SG min/max 0/134, reads 52949, writes 0 timeouts 0
      Driver 2: pos 3962, standstill, SG min/max 0/1023, reads 52949, writes 0 timeouts 0
      Driver 3: pos 0, standstill, SG min/max 0/665, reads 52949, writes 0 timeouts 0
      Driver 4: pos 0, standstill, SG min/max n/a, reads 52949, writes 0 timeouts 0
      Driver 5: pos 0, standstill, SG min/max n/a, reads 52949, writes 0 timeouts 0
      Date/time: 2021-10-06 01:17:08
      Slowest loop: 43.27ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 30, maxWait 3245ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 916, completed 916, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 1770, received 3305, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 8, free buffers 49 (min 47), ts 825/825/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      State: 4, failed transfers: 0, checksum errors: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 17824/17824
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c488
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.4-b4
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 38.81, max wait times: 43.5ms/5.7ms
      Codes per second: 1.39
      Maximum length of RX/TX data transfers: 5824/1828
      File /opt/dsf/sd/gcodes/top_dedication.gcode is selected, paused
      10/6/2021, 1:17:05 AM M600
      Printing paused for filament change at X280.5 Y286.5 Z0.2
      10/6/2021, 1:16:57 AM Resume state saved
        dc42 administrators @janusofdoors last edited by
        @vishiano restarting prints instead of resuming them when using SBC is a known issue in 3.4.0beta4. We expect to release beta 5 to fix this later today.
        janusofdoors 1 Reply Last reply Reply Quote 0
        • janusofdoors
          janusofdoors @dc42 last edited by
          Oh, well that's good news! Do you have a list of known bugs somewhere, before I posted I did some searching on this issue and didn't find anything.
            dc42 administrators @janusofdoors last edited by dc42
            @vishiano we only found that bug a day or two ago, so it hasn't made it to a bug list yet. We do sometimes add a "known issues" section to release notes. Eventually they will be moved to github issues.
