    Solved Error: unknown variable 'global.magprobestatus'
    Gcode meta commands
    • thaug29
      thaug29 last edited by
      I am trying to run this macro but I keep getting the error unknown variable. This is a Duet 3 6HC with SBC, what am I doing wrong.
      if sensors.probes[0].value[0] = 0
      set global.magprobestatus = "attached"
      elif sensors.probes[0].value[0] > 500
      set global.magprobestatus = "docked"
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @thaug29 last edited by fcwilt
        @thaug29 said in Error: unknown variable 'global.magprobestatus':
        You have to create a variable before you can refer to it with a set command.
        To create the variable you would use something like:
        global magprobestatus = "unknown"
        That is not a typo, there is no period, there is one space.
        I create my globals in config.g.
        thaug29 1 Reply Last reply Reply Quote 0
        • thaug29
          thaug29 @fcwilt last edited by
          @fcwilt said in Error: unknown variable 'global.magprobestatus':
          Thanks You, that did it!
