    web interface not loading
    Duet Web Control
    • Napalm1432
      Napalm1432 last edited by
      Hey all,
      I've just returned to my printer having finally got the right PSU.
      I have the duet 085 with ethernet, and i had already done all my configurations, but now when i turn on the printer (hooked up to ethernet) the web interface is not loading at all, i simply get a 404 error.
      I checked if it was recognized in the network via the router and it shows up there with the ip.
      When i try connecting to the ip nothing loads. I have tried a different duet and the same issue occurs, also tried multiple sd cards.
      I tried hooking up usb but it won't show up in devices at all so connecting trough usb was not possible for me either.
      Does anyone know how to resolve this issue?
      Let me know if you require more info.
      • Napalm1432
        bump? still having this issue
        chrishamm 1 Reply Last reply Reply Quote 0
        • chrishamm
          chrishamm administrators @Napalm1432 last edited by
          @napalm1432 If you get a 404 error, that means you do not have the web interface files in /www. Download DWC for Duet 0.8.5 again and extract everything into the www folder on the SD card (create if first if it doesn't already exist).
          Duet software engineer
            I'm surprised that nothing also shows up via USB. What files were present on the SD card?
