(EDIT) Already supported in RRF - Mesh probing with Rel Ref Ind
@gixxerfast said in (EDIT) Already supported in RRF - Mesh probing with Rel Ref Ind:
BTW: The -3 flag to the G30 will produce the same result just the other way around, adjusting the probe offset instead of the read height value ?
Yes, G30 S-1 will adjust the trigger height to match the current Z instead f the other way round.
Use the K parameter on the G30 and G29 commands to select which Z probe to use for each command.
