    Duet WiFI 1.19.2 from 1.18 upgrade - DWC won't connect
    Firmware installation
    • mhackney
      mhackney last edited by
      David, I followed the upgrade docs to the letter and all went well. I checked firmware version wth M115 and see 1.19.2. I then did M552 S0 and wifi module started. Ran my SetNetwork macro followed by M587 and see my network. I then run M552 S1 and get:
      Wifi module is connected to access point "OBFUSCATED", IP address "OBFUSCATED"
      So at this point, everything is good. This is where things get odd…
      I open a browser and open the DWC via the IP address reported above. The DWC loads and attempts to connect to the printer and fails. After that, it won't load again.
      I have to reset the Duet WiFi and go through the M98, M552 again to get back to this point. I actually seen DWC connect twice but then immediately disconnect back to this state that needs to be reset.
      I'm in that state now. If I run M552 Sq I get the correct:
      and M587 shows my remembered network but I can't load DWC.
      Any suggestions or any debugging info I can provide?
      thanks,
      Michael
      My 3D Printing blog: http://www.sublimelayers.com
      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
      • Dougal1957
        Dougal1957 last edited by
        did you copy all the DWC Files to a folder under root called WWW easy to miss that bit
        • mhackney
          Yes I did and the fact that it actually displays the DWC interface confirms that.
          But, I seem to be working now. I removed and reformatted the SD card and rebuilt it from scratch. I then went through the upgrade procedure and this time, the DWC connects to Duet and stays connected.
          Case closed but I don't understand what the initial problem was.
          • Dougal1957
            Michael sorry didn't spot it was you but? David does also advise to delete the existing WWW Folder Which I am sure you followed anyway glad your sorted now
            • mhackney
              Ok, just to close this out here…
              I believe I had several unrelated issues that compounded diagnosing this but I seem to be very stable now.
              1. I was running at 64 microsteps with a resulting MaxReps: 411 (M122) which David said is too high. This contributes to disconnects while actually printing. I lowered microsteps to 32 and my MaxReps is now 117. I have not had a disconnect during a print since.
              2. A big issue was poor WiFi reception with the Duet in the base of my metal framed D300VS delta. I installed a wifi extender and the signal is MUCH stronger. I still got disconnects during idle but not as frequently.
              3. My Settings->General->Maximum number of AJAX retries was set to 1. I changed that to 3 as per the new "wifi disconnect" wiki. I have not had a disconnect during idle or print for over 48 hours now.
              • mhackney
                A follow up on the follow up - another 2 days without a single disconnect. Looking good!
                • str8up
                  str8up last edited by
                  A little off topic. Can someone tell me where the gcode files are being saved on SD card 0? It goes through the download process. I have to change directories to something off root before it shows up. Another thing I am seeing is my setting - Temp additions ATX on / off are not there after a restart. I am using 1.19 +3.
