    Deceleration calculated next step time negative?
    Firmware developers
    • jazbaatbadalgaye
      jazbaatbadalgaye last edited by jazbaatbadalgaye
      I wrote a snippet to verify if I understand how the next step time is generated for acceleration and deceleration phase. I am getting sensible values when I print values out for acceleration but when I print values for deceleration, I am getting negative values. I have set up some dummy values for the variables and my best guess is some of those values might be incorrect. Any help is appreciated
      #DECELERATION
      #Move G0 X5
      totalsteps=400
      totaldistance=5
      stepsPerMm = totalsteps/totaldistance
      topSpeed=500
      requestedSpeed=400
      deceleration=1500
      endSpeed=0
      startSpeed = 300
      StepClockRate = 937500
      acceleration = 2000
      compensationTime = 0.3
      shiftfactor = 3
      nextStep = 200 #no of steps done
      stepsTillRecalc = (1 << shiftfactor)-1 #store number of additional steps to generate
      compensationClocks = compensationTime*StepClockRate
      decelDistance= ((requestedSpeed**2) - (endSpeed**2))/(2*deceleration)
      decelStartDistance = totaldistance - decelDistance
      accelDistance = ((requestedSpeed)**2 - (startSpeed)**2)/(2*acceleration)
      steadyTime = (decelStartDistance -accelDistance)/topSpeed
      accelStopTime = (topSpeed - startSpeed)/acceleration
      decelStartTime = accelStopTime + steadyTime
      fTwoCsquaredTimesMmPerStepDivD=StepClockRate*StepClockRate*2/(stepsPerMm*deceleration)
      print(fTwoCsquaredTimesMmPerStepDivD)
      topSpeedTimesCdivDPlusDecelStartClocks=(topSpeed*StepClockRate)/deceleration + decelStartTime*StepClockRate
      adjustedTopSpeedTimesCdivDPlusDecelStartClocks = topSpeedTimesCdivDPlusDecelStartClocks - compensationClocks
      print(adjustedTopSpeedTimesCdivDPlusDecelStartClocks)
      nextCalcStep = nextStep + stepsTillRecalc
      temp = fTwoCsquaredTimesMmPerStepDivD * nextCalcStep
      print(temp)
      fTwoDistanceToStopTimesCsquaredDivD =((topSpeed*StepClockRate)/deceleration)**2+ ((2*decelStartDistance*StepClockRate*StepClockRate)/deceleration)
      if temp < fTwoDistanceToStopTimesCsquaredDivD:
          nextCalcStepTime=adjustedTopSpeedTimesCdivDPlusDecelStartClocks - (fTwoDistanceToStopTimesCsquaredDivD - temp)**0.5
      else:
          nextCalcStepTime =  adjustedTopSpeedTimesCdivDPlusDecelStartClocks
      print(nextCalcStepTime)
      bot 1 Reply Last reply Reply Quote 0
      • bot
        bot @jazbaatbadalgaye last edited by
        Just a wild guess here, but perhaps RRF uses negative values in that context to indicate deceleration vs acceleration.
        That, or the lookahead queue is being overrun and the move can't be adjusted (or whatever happens), causing the time to be invalid.
        *not actually a robot
